General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Should the exterior temperature be displayed? [solved]
Old Feb 22, 2023
JJinQC's Avatar
JJinQC is an unknown quantity at this point
Unhappy Should the exterior temperature be displayed? [solved]
Just purchased a used Civic Coupe LX 2012 (in Canada). I noticed that the exterior temperature is not displayed and does not appear in the menu setup. A note in the owners manual indicates that it is available only on certain models. Considering that the LX is pretty much full equipped is it normal? Is there something I can check to verify for example if a sensor is located in the front bumper? Any suggestions?
Thanks in advance!
Old Feb 22, 2023
re: Should the exterior temperature be displayed? [solved]
LX isn't the fully equipped trim. For the sedan, it was the 2nd lowest trim level. For the coupe, it's the lowest
DX (4-door only) > LX > EX > EXL > Si
Looking at the part number for the 2012 Civic ambient temperature sensor, the LX is not a compatible model. Tells me that the LX does not come with ambient temperature monitoring
source: https://www.hondaautomotiveparts.com...EtOGwtbDQtZ2Fz
That site caters to the USDM market, but seeing as how it lists neither the LX or DX, I'd imagine the CDM follows suit
Old Feb 23, 2023
JJinQC's Avatar
Re: Should the exterior temperature be displayed?
Thank you very much for the information!
I found information about adding the ambient sensor and adding to the display menu. But it involves quite a bit of work including dash board removal (part of it). I will reconsider the job next summer when the outside temperature is more friendly. If I do I will post the information on this site.
bobt1962
General
Jun 28, 2021 07:57 AM
2002ExCivic
16
Nov 29, 2016 08:29 AM
rev29
Mar 28, 2013 05:14 PM
