General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Maintenance schedule
Old Aug 6, 2018
zorrox's Avatar
zorrox is an unknown quantity at this point
Hello civicforums!
I have a 2013 sedan that is coming up on 30k. I was looking through my manual and online for a recommended maintenance schedule and couldn't find anything. I'd rather not take it to the stealership, can anybody point me in the right direction? Thanks!
Old Aug 6, 2018
Colin42's Avatar
Re: Maintenance schedule
The Honda website should give you the maintenance schedule. The Canadian one does.
Old Aug 6, 2018
GolNat's Avatar
Prelude Owner
It should be in the manual. Might look like this
2013 probably has the fancy maintenance minder thing that will display a code like 1,2,5 or something like that. There is a chart in my Fit and Pilot manual that tells me what the numbers mean and has all the basic maintenance listed.
Like Colin said check Honda website also.
Old Aug 6, 2018
GolNat's Avatar
Prelude Owner
Could look like this but maybe this is the older format for the cars with just the green, yellow, red window that you reset with your key
Old Aug 7, 2018
There is no old school "schedule" anymore, it's now the Maintenance Minder system.
See YOUR owners manual, starting on page 257.
Oil change and tire rotation at every service interval
Around 24-30k it wanted both air filters replaced. Were these done?
We always recommend ATF service every 30k, regardless of what the minder system wants!
Brake fluid service every 3 years. If never done, it's due.
Original tires might be due for replacement by now.
Alignment whenever it gets a set of tires.
Tune up (spark plugs) ~100k
Coolant 10 years/~100-120k, then every 5/~50 thereafter (check your manual for actual mileages, but you probably will need to be doing this based on time instead of miles)
Other stuff is to be inspected and addressed as needed.
Jackie1993
Jan 15, 2018 04:57 AM
Bellz
May 7, 2017 07:55 PM
glowe
Sep 17, 2015 12:00 PM
Shlomo
Apr 11, 2003 04:57 PM
FutuRisticCiViC
Jun 5, 2002 11:42 PM
