General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Upgrade wipers to full intermittant
Old Mar 28, 2019
SC Tiger's Avatar
SC Tiger is an unknown quantity at this point
I have a 2010 Civic that has the "psycho wiper" issue. From my research this is due to the park switch going bad in the motor. I have a couple of questions:
1) Can the switch be replaced separately or do I have to replace the entire wiper motor?
2) If I replace the motor, is it possible to go from the semi-intermittant system I have now (where it only has one intermittant speed) to the one where it has several speeds available similar to the Pilot, Accord, and I think higher-end Civics? What would be involved in that? As I recall, when I bought the new wiper stalk (thinking it was the problem) there was an option for one that had the full range of speeds on intermittent.
Thanks in advance.
Old Mar 28, 2019
Colin42's Avatar
Re: Upgrade wipers to full intermittant
I was able to do that on my 05, the connector for the wiper switch had the correct number of wires so I just put in the variable intermittent switch. You probably need to replace the motor.
I would just grab the motor and linkage from a low mileage car in the junkyard. And grab all the cowl clips so you have extras for when you break the ones on your car
Old Mar 29, 2019
CraigW's Avatar
The variable wipers require a single wire to the MICU/Fuse box.
Old Mar 29, 2019
Colin42's Avatar
so that would be similar to the 05 which has 2 extra wires for the variable intermittent.
this is what it looks like for an 05:
https://www.civicforums.com/forums/1...nt-wipers.html
Old Mar 29, 2019
SC Tiger's Avatar
When I replace the motor I may give it a shot. If I have the two wires I'll do it but I'm not running an extra wire just to do that.
Old Mar 29, 2019
Colin42's Avatar
From what CraigW said it sounds like you would just have one extra wire in the switch connector. Only way to check is to find the connector and check the number of wires.
Old Mar 29, 2019
CraigW's Avatar
Here is a helpful link for the 8th gens.
https://www.8thcivic.com/forums/diy-...-stalk-ex.html
Colin42
Jul 3, 2017 11:59 AM
Kris20072001
Dec 5, 2010 01:45 PM
shanti.vt1
Feb 28, 2010 08:06 AM
Spartanic
Jun 29, 2009 06:34 PM
nupe494
Feb 14, 2007 03:44 PM
