2005 civic lx wiper delay problem
Hello,
I own a 2005 civic 4 dr lx. When I turn the wipers on Int they get stuck h Salf way and dont go back to home position. Speeds 1 and 2 are fine when they are selected. As soon as I switch it off it gets stuck again.
Could this be the wiper delay or the motor. Any help would be great.
thanks
thanks
Re: 2005 civic lx wiper delay problem
My first thoughts are the park switch in the wiper motor...
If you quickly bump the mist operation and let go do they stop once you release the lever as well ??
Could it be the wiper assembly?
There is a switch located in the wiper motor assembly called a "park switch" If the wipers are turned off during the middle of a cycle then the switch allows the wipers to go back down and stop. It would work with intermittent mode, mist & any time the wipers are not all the way down.
It could well be the park switch has failed, you may want to get 2nd opinion as I see the motor is a bit expensive. And certainly not a common problem either.
It is electro-mechanical (if that is a word ?) it is contained inside of the motor assy.
The other thing to try would be remove & reseat the connector going to the wiper motor.
Why No... I bought my 05 new 5 years ago and read on this site about early 7th gen auto tranny issues and as a result have changed my atf fluid every 25k miles using only Honda ATF-Z1. Perfect except for that damn grade logic, hate it.
I have had my 05 Civic since new and no problems with Auto Tranny at all. I get my oil changed every 5000KM and Tranny Fluid Every 80000 KM. Currently have 125000 on my Civic...
Off topic for sure.
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
