General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Upgrade Headlight & interior bulbs?
Old Jan 14, 2019
SoundCivic's Avatar
SoundCivic is an unknown quantity at this point
Question Upgrade Headlight & interior bulbs?
Hello all..... Long time civic owner....New member and first time post!
I recently purchased a 2007 Civic LX 1.8 Coupe Manual.... I'm in the process of fixing her up and adding some upgrades.
I'd like to upgrade the stock Sylvania High Beams and Low Beams (9005 NB3 & 9006 HB4).
I don't need anything to crazy..... Just something a little bit brighter.......Ideally bright white..... Is there something you guys would recommend that would last a LONG time.... I've read that the inner reflectors on the OEM headlights are not designed to work with the newer LED bulbs so I'm assuming Halogen is the way to go..... I just need something easy without having to worry about frying the wires, making custom mods etc....
​​​​​​I'd also like to upgrade the interior dome light bulbs and license plate bulbs.....Would LED be a good option? If so which is the best without breaking the bank?
Thanks
Old Jan 14, 2019
Re: Upgrade Headlight & interior bulbs?
headlights, switch to 9011 and 9012 HIR bulbs?
Old Jan 14, 2019
FJP326's Avatar
FJP326 is an unknown quantity at this point
I picked up some LED replacements for the interior lights on Amazon. Was $5.99 for a 6 pack. Twice as bright, and they have a nice color to the light produced. 6000k temp, and produce 600 lumens per bulb.
Old Jan 17, 2019
SoundCivic's Avatar
Thanks! Do you happen to know what brand it was? There’s pages and pages full of interior lights.... Just want to get a good set.
Old Jan 17, 2019
FJP326's Avatar
I used these in a 2009 Civic. I also have a 2017 SI, that uses different bulbs, so make sure yours uses same type.
Old Jan 17, 2019
SoundCivic's Avatar
DOPE! Thanks man!
jonros
Lighting DIY
Aug 28, 2019 11:23 AM
carid
Oct 20, 2014 04:48 AM
richs1000
General 7th Gen
Jul 17, 2011 12:00 AM
noromac0
Aug 23, 2010 06:56 PM
gearbox
Lighting
May 10, 2004 05:09 PM
