Stupid Interior Lights
Old Jul 16, 2011
richs1000's Avatar
richs1000 is an unknown quantity at this point
Other every month another bulb burns out. Anyone else have a lot of burned out interior lights? Just curious.
Old Jul 16, 2011
lazlong's Avatar
Re: Stupid Interior Lights
Never had to replace one, and I've had the vehicle 4 years. It's either cheap bulbs or the voltage is fluctuating or the voltage is too high. The bulbs are designed to take some higher voltage but, not a whole lot. Take the bulb out and measure voltage from the positive lead to body ground. Post back with results.
Old Jul 16, 2011
richs1000's Avatar
all of the interior lighting is stock though.
Old Jul 16, 2011
CraigW's Avatar
What brand bulbs ?? Try Sylvania or other name brand & certainly avoid GE bulbs from walbobs. I always try to wipe mine with isopropyl and then not touch the glass when installing (kind of **** for a small bulb maybe)
Old Jul 17, 2011
try a 194 bulb instead of 168 for the front, its rated for 2500 hrs of use. and a 5w ferstoon for the rear instead of 8w. i have leds in mine so i havent noticed any burning out problems. i can see why the filament bulbs would burn out being in such an enclosed area. if you leave them on for more than 30 secs, you will start reducing life fast. and yes wiping them clean is a great idea even for mini bulbs. they still run at 165F or greater and oils on the bulb can cause hotspots.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
Cross
Dec 9, 2001 05:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
DaPipeLayer
Nov 14, 2001 08:06 AM
