is this true??
Old Jul 19, 2011
floyd107's Avatar
floyd107 is on a distinguished road
is this true??
i was at the shop buying some synthetic oil and one of the people asked what year and when i told him 02 he was like NO!! YOU WILL CAUSE MORE PROBLEMS THEN ANYTHING. he said its too good of a oil and it will blow seals and gaskets. so idk what to do because i want to swich over to synthetic but i dont want to be dealing with those type of problems. is this true?
Old Jul 19, 2011
MindBomber's Avatar
Live for the Twisties
Re: is this true??
How many miles are you at?
Old Jul 19, 2011
Re: is this true??
ive been using valvoline synpower for a year and now redline for 6 months. nothing bad happened to my 02 civic and it has 100k on it currently.
Old Jul 19, 2011
floyd107's Avatar
Re: is this true??
i have 140k but i have never used it before. im just now switching over.
Old Jul 19, 2011
MelJ's Avatar
Trance Addict
Re: is this true??
I think the only problem that could possibly arise is if you had a small leak, it's probably gonna be much worse. Other than that, if the car is in good mechanical shape, you should be fine.
Old Jul 19, 2011
Re: is this true??
its hard to say what your engine is like inside without knowing anything about how you drive and do maintenance. many factors can lead to a bad engine without you even knowing you did anything wrong. you could always run a treatment of auto-rx.com first and then switch to synthetic after its completed. synthetic should not cause problems in a good motor, no matter how many miles it has.
Old Jul 19, 2011
floyd107's Avatar
Re: is this true??
ya i dont have any leaks only thing is a warped oil pan gaskit but it dosent leak at all my oil level is always about the same. and my car is babied i change the oil every 3k and plugs every 6k. i stay up with all my other fluids.but with that said i will probably do my oil pan gasket and search for anything else to be sure i dont have any probs. is there anything thing else im missing or should no.
Old Jul 19, 2011
Re: is this true??
thats pretty much it. just do a regular oil change and fill it up with synthetic. most of them will go 10k miles easily so you may only want to change the filter at 5k miles. i normally just do mine every 10k miles/10 months together and never have a problem. you may want to watch the dipstick for a while after switching. i had some oil getting lost at first that seemed to go away after a while.
Old Jul 20, 2011
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: is this true??
The last oil change I did in my old civic (bought a nicer one) I used synthetic and that had 150k on it. Plus the engine wasn't in great shape. It was running but not too great. No leaks or anything.
Old Jul 20, 2011
pheaton's Avatar
A descendant of 2k1civic.com
Re: is this true??
I've ran a few different things over the years. But I've mostly ran a synthetic blend or a full synthetic pretty much the entire life of the engine. I have a 140k now and still going strong. I think my oil pan gasket is starting to seep, but it's not dripping. So I'll leave it for a bit.
Old Jul 20, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: is this true??
Although not fully synthetic, I run mobil 1 every 3~5k ever since 35k miles
I'm nearly tippin 68k now
Engine feels smoother and quieter with it
Old Jul 20, 2011
SpeedDownZone's Avatar
Re: is this true??
I used to use synthetic oil and changed every 8k-10k and never had a problem. Oh and I used 5-30 and I always though the motor was quieter than 5-20.
Old Jul 20, 2011
Kenny the Ricer
Re: is this true??
^ Agreed, I'm running 5w-30 too
Only works in non harsh environments though, like the bay area :P
Old Jul 20, 2011
MelJ's Avatar
Trance Addict
Re: is this true??
I can honestly say M1 makes my Civic happy. The Max Life I have in there now isn't bad, but I can tell the difference from when I had the M1 running in there.
Old Jul 20, 2011
floyd107's Avatar
Re: is this true??
ya m1 is what i will go with ill probably use 5w-20. has anyone noticed any mpg changes with using synthetic oil. i gess it should be better (so i heard).
Old Jul 20, 2011
Kenny the Ricer
Re: is this true??
Doesnt effect MPG...
If anything, It's made me lose MPG due to my lead foot XD
Old Jul 20, 2011
richs1000's Avatar
richs1000 is an unknown quantity at this point
Re: is this true??
you will be fine. Maybe a possible leak or increased leaking if it leaks already.
JetsterDajet
52
May 8, 2016 12:11 AM
sesi
Oct 1, 2015 02:03 PM
JMKendrick
Sep 16, 2015 06:17 PM
MamaBear2015
Aug 27, 2015 09:29 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
