Future Civic Owner (hopefully, Pls help)
Hey Guys im getting rid of my 4x4 truck and im looking to purchase a honda civic. Im checking out a 2007 Civic Ex Coupe manual with 117k. they have it listed for 6800. is this pretty fair and are there any common problems or issues i should look for when inspecting it? i know nothing about civic so anything will help!!!
Re: Future Civic Owner (hopefully, Pls help)
As dlayman states maintenance records are important. Consumer reports has good reliability data I have found to be quite accurate and is what I will use before my next vehicle purchase. Throttling it hard in first gear then quickly letting off the gas will produce a puff of blue smoke if the engine has significant issues (burning oil). A friend needs to watch this from the street as you pass by. With a bright light check all engine and transmission areas for signs of leaks. Check connection points of body panels, if differences in paint are noted it has likely been in a wreak.
CarStuff
Dec 6, 2020 12:52 PM
Is there any 2k1 civic owners that lives in or around Humble, Texas area?? One question for the Hous
viper775
South
Nov 8, 2001 07:40 AM
