General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
CVT Question
Old Jan 2, 2019
twichy2011's Avatar
twichy2011 is an unknown quantity at this point
CVT Question
Hey guys,
I'm new to the honda forums (I typically live in the corvetteforum) and figured I'd ask a question that I have been searching for an answer for a while. My girlfriend has a 2012 Honda Civic Hybrid which recently got a Maintenance Reminder stating that the transmission fluid needed to be replaced. I'm not the most informed about CVTs since I do not own a car with a CVT. I prefer the good ole standard transmission. Back to my question.... I can not find any information in the owners manual about a filter replacement schedule for the transmission. Do these transmission have a non serviceable filter? I have found several gasket/ filter kits. The filter looks like it should not be difficult to replace. If I have overlooked anything obvious, please excuse my ignorance.
Thanks,
Connor
P.S: I am very comfortable doing car work. I have access to a lift, so getting the car in the air is not a problem. I have done extensive engine and trans work on my ole 92 corvette. (more of my wheel house)
Old Jan 3, 2019
Re: CVT Question
Filters are not replaced as routine. (it has a strainer 'screen door' in the pan and it should have a filter canister in a cooler line)
Routine fluid service is simple drain and fill. Approximately 3 quarts for a single fluid service.
Correct fluid for that one is Hondas CVTF (pictured below) NO SUBSTITUTES
Old Jan 3, 2019
twichy2011's Avatar
Re: CVT Question
Thanks for the info! Very seldom do I stray from the recommended specs in the owners manual.
Thanks,
Connor
dsm482
Auto Transmission failures
22
Dec 23, 2016 02:25 AM
teraric
May 13, 2013 03:08 PM
BahstonCivic
Oct 2, 2012 01:18 PM
96beatercivic
Jun 18, 2012 05:36 PM
philsep36
Mar 24, 2004 01:26 AM
