General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Dirty engine bay
Old Jan 29, 2022
Pnutt559's Avatar
Pnutt559 is an unknown quantity at this point
Dirty engine bay
I own a 2007 civic si, my engine bay is a little dirty, is it safe to pressure wash it? Or what would be the best way to clean it up, thanks in advance.
Old Jan 29, 2022
FRSam's Avatar
Click Here
Re: Dirty engine bay
I had a friend who was a detailer at the Honda dealership and he used to pressure wash the engine bay.
Old Jan 29, 2022
if you did not splice wires and connectors are firmly plugged in, they should have some water resistance (no dizzies in these gen)
Old Jan 29, 2022
Never done it myself, but common sense applies: cover the alternator and the battery. Simple green is a good choice for degreaser
No lie, the only time I cleaned my engine bay in my 2002 is when I had the engine and tranny out. You best bet I got that thing sparking though. I've always been too much of a wuss to do it otherwise. lol
Old Jan 29, 2022
Colin42's Avatar
I've used the aerosol canned stuff and a hose. Just follow the directions on the can
Old Feb 2, 2022
A1EK's Avatar
A1EK is an unknown quantity at this point
Hi all quite new here. Just did my engine bay and from experience of other cars have never had an issue. You have to remember that modern cars use IP rated connections, you may see the wires however the plugs should be sealed fine.
My method is quick and easy, get some degreaser and a little soft paint brush and go liberally all over working the brush into all the places you possible can.
Leave for a few minutes and then blast with the jet wash.
Then start the car and let it warm slightly.
Now importantly, use AutoGlym 'Vinyl trim spray' or 'tyre spray' leave for 10 mins and have a look at your engine it will gleam !!
good luck
k-man
Detailing
46
Feb 25, 2006 01:21 PM
robo1040
Feb 16, 2005 01:56 PM
jawn_myek
Detailing
17
Jul 4, 2004 12:45 AM
iceman
South Cali
Oct 7, 2003 12:48 AM
xHoteKx
Detailing
Feb 6, 2002 08:25 AM
