View Full Version : Electrical
- 2000 Honda Civic No Crank No Start(kill switch)
- 1998 Honda Civic 1.6 DX alternator issues
- Back up lights stay on in all gears
- 1998 Tachometer suddenly not working
- 2000 D16Y8 engine with OBD2A harness and ECU
- Lights not working?
- '98 EX No Spark
- DRL Not working at all?
- 1999 VTech O2 Sensor Resistance and Schematic?
- 1998 Civic Manuals?
- Need Help: Car Won’t Start, Alarm/Panic Mode Issue?
- Big 3
- Wiring harness Problems
- random 5 pin connector with 4 cables (for what is it)
- Key in ignition beeper keeps going without key in [solved]
- Beeping issue
- Instrument Cluster and Driver Side Speaker Issue [solved]
- Gauge Cluster Lights [solved]
- Where is the Fail Safe Relay 1998 Civic EX Coupe
- need help 99 civic ex
- Bizzare Turn signal issue
- Window problem for 2000 Honda civic sadan
- Car clicks and looses all power right before I go to start the car (ignition )
- Gauges go wild when I use my turn signals
- ABS light if RPM more than 2500
- 98ex won't start from ignition
- Identifying a mystery relay connection [solved]
- Problem with fuse for fuel pump
- Kill switch fuel pump relay (gone wrong) 99 civic LX [solved]
- 98 civic dies mid drive
- 98 Civic LX No power on start
- Battery or alternator problem.
- my dash blinks when i use my turn signal
- 97 Honda Civic, clicks and turns off
- Driverside front running light stopped working.
- 98 d16y7 2 wire signal to 3 wire IACV
- 1999 civic turn signal light not working when headlights on
- 1997 DX Sedan, no accessory power to radio harness.
- Alternator went out. What did it mess up?
- Radiator fan only works if i unplug the plug where the radiator and ac fan go
- CEL p0500 on a 97 civic ex
- Electrician in FL
- 97 Honda Civic window motor is not working
- 99 Civic Lx, driver side window broken into, now other windows no longer functional.
- ECU died - AGAIN!
- No power anywhere
- Won’t start got me stumped
- Please help please
- Fluctuating temp gauge after taking out and re installing cluster [solved]
- Backup Lights Are Paper Weights
- Em1 Headlight issue
- Please help 98civic
- [2000 base model] No power to heater/fan after I unplugged it and plugged it back in
- 97 DX coupe Brake light/Turn Signal issue/reversal
- 99 honda civic ex. Underdash fushbox
- 97 Civic DX no power to Fuel Gauge sending unit
- Hacked/aftermarket push-button ignition has broken - please help with fixing!
- '96 Civic no crank, no headlights
- Power windows intermittent 96 Civic [solved]
- Finding the downstream O2 sensor connector
- Mystery connector under intake manifold?¿
- Strange power window behaviour
- Is there a fuse for door jumb switches ?
- 2000 Civic LX-V P1298, No Start, & Blowing Fuse 15
- Rear taillights not turning on
- Driver's window problems: 1996 Civic EX [See below]
- Any idea where this plug goes ?
- 98 homda civic sensor help
- 98 LX Model flashing interior lights [solved]
- 97 Civic Power Windows Issues- No Ground?
- 1996 EX 4 Door Electric Windows Issue
- Primary O2 sensor
- Driver door locks when you pull door handle
- 2000 Honda Civic DX
- 2000 civic ex 5 speed ignition no fuel no start
- Head unit issues
- DRL Wiring
- Lights turn on with engine
- Fog light harness has no power [solved]
- Body wiring harness location on a 98 CX
- Horn wire
- 96' EU EJ9 Civic Adding a dimmer switch?
- No power to head unit
- I shorted out my kill switch on the metal dash bracket
- 96 Honda Civic EX Coupe - is there supposed to be 17 wires coming to the driver door?
- 96 Civic - Power mirror adjust switch activates door lock
- 96 Honda Civic Passenger window doesn’t want to go down, electrical problem
- jdm non vtec d15 distributor wiring
- Temp control lights
- P1298 code on 1999 honda civic si EM1
- Speedometer needle not calibrated to zero
- All lights pulsing?
- Cluster Gauge Lights
- Obd isnt reading
- Coolant leak battery fuse blown
- 6m Nut for battery hold down - a little help making sure I got the right one?
- door locking problem
- Power locks problem
- Fuel gauge stuck in Full [solved]
- Leaving Honda Unattended for several months - battery maintenance question
- A/C won’t switch between face/feet/defrost
- Gauge cluster lights
- Obd1 Gsr swap onto obd2 (2000 civic)
- Speedometer not working, help?
- 2000 Civic si sensor problem
- Random shut off
- Window issues
- Parasitic Draw? - 1996 Civic VTi hatchback
- Tach wire
- 2000 Civic Back Up 7.5 Fuse Problems
- 1998 civic dx tach doesn't work
- CEL on, car won't start but will crank, CEL off, car will start
- IACV from 2 wire to 3 wire, need confirmation
- 1996 honda civic fuel gauge problem
- Reverse battery, no power after replacement of fuse
- Fuel Pump
- key wont come out, car wont start. auto trans
- 96 hatch dx wiring harness is butchered
- Ek sedan Domani trunk wiring issue
- Car won’t start D4 flashing check engine on
- 1999 Honda Civix LX 1.6l with p1509 code check engine light
- Crx tach not working
- So I got my first question to ask
- Civic 2000LX Connect new batt & horn blows.
- 1999 Honda Civic DX , constant power to ignition control moduleEVENwith ignition off
- 1998 Civic ex 5 speed reverse lights stuck on even with the switch unplugged
- Dash lights not working could it be the dimmer seitch
- Weak cold startup, takes multiple startups to stay on.
- Fuel light not coming on
- 97 Civic extremely high idle and intermittent surge
- Main window control switch will not operate passenger window.
- 1995 civic runs rough intermittently
- Cluster swap 00 civic ex to 03
- Door Lock Trouble
- 2000 civic lx code p501
- Dome light stays on
- Shift interlock problem
- Civic DX Coupe Alternator?
- 97 Civic Rear Running Lights keep blowing fuse
- Civic 03 still horn after closing it
- All locks wont work
- No crank. Will push start
- 99 civic ex problems
- Bank 1 Sensor 2 High voltage
- No crank, cel doesn't turn on, dash board is on
- Blower Motor Not Working
- kswap civic no spark
- Raditor fan relay fuse not working well
- Electrical load problems, intermitent, power loss
- Odd Turn Signal Problem
- Gas gage wont work
- Faint Battery Lamp, Bad Alternator Diodes?
- 99 Honda Civic Battery Light
- cluster lights on a 1999 Civic EX sedan
- 96 Civic Temperature Gauge Problem
- Tachometer NOT working ...
- Engine Management Light on
- Radio blacks out
- 1997 Replacement ELD
- Pegged temperature gauge (2000 DX)
