Electrical Post your Electrical issues here!
Door Lock Trouble
Old Jul 28, 2019
Reedtech's Avatar
Stoned Mechanic
Reedtech is an unknown quantity at this point
Door Lock Trouble
I just purchased this 97 civic a month ago and the door locks aren't working properly. They both are getting power and ground and both make clicking noises. The manual switches are both half engaged, trying to lock or unlock them does nothing. I am able to lock the driver side with the key only while holding the outer door handle out while I turn the key. The passenger side does not lock manually or at all. I do not have keyless entry or a fob for it. I tried to reset multiplex unit by turning wipers to intermittent then turning key on and off. No change. Any help would be great!
Old Jul 29, 2019
Colin42's Avatar
Re: Door Lock Trouble
probably just aren't strong enough anymore to work properly, probably need new actuators.
having to hold the inner handle to either push down the **** or hit the lock switch is normal.
passenger side you should pull of the door car and have a peek in there see if something is seized
Old Aug 5, 2019
Reedtech's Avatar
Stoned Mechanic
I ordered two new ones they will be here in two days. I'll update with the results.
lpozzo
Dec 14, 2017 06:56 PM
Laurentd
Apr 26, 2017 09:03 PM
Steven Corns
Jun 10, 2016 09:35 AM
boosted2cam
Exterior
Feb 2, 2010 12:02 AM
schreibers
Dec 20, 2009 07:51 PM
