Battery or alternator problem.
My ‘98 Civic dies on me every few days. It started with a dead battery that I removed from the car and charged up with a battery charger. Car started fine and ran fine for 2 days. Tonight on the way home, the dash lights went dim, the speedo and tach went to zero, and the headlights I could barely see. When I jumpstart the car and with it at idle, if I disconnect one of the battery cables, the car dies.
Battery is an Interstate Battery that is about 5yrs old.
Alternator is at least 15yrs old.
Re: Battery or alternator problem.
Bring it to an auto parts store to have them test the alternator and battery free of charge. Also, check tension on the alternator belt to be sure it's not too loose.
Most likely alternator but it may have killed the battery. Don't buy a crappy parts store alternator. These cars don't like aftermarket electronics
Also, what is best way to replace….from the top or underneath? Looks like I may have to remove the front, driver side tire.
From the bottom, tire off is alot easier. Grab one from a junkyard if you don't want to pay for a new oem one.
desk0
15
Nov 9, 2011 10:20 PM
mrchowmein
Jan 25, 2005 05:07 PM
doctor
Jan 27, 2003 03:56 PM
