Won’t start got me stumped
I have a 99 Honda Civic when I turn the key over if the check engine light doesn’t come on the fuel pump won’t prime and the car won’t start it will turn over but not start. If the check engine light comes on the fuel pump primes and the car will start but I can’t find a common factor as to why this is happening can anyone help
Re: Won’t start got me stumped
what code?
some connectors loose somewhere? wire damage?
pull check and put back fuses to see if is just loose fuses? know a guy that knocked a fuse out of place when removing a different fuse
Duh I knew that lol ya know it just pops on when you turn the key over just before you start it The battery light the oil light the seat belt light and the check engine light all come on when you turn key over then goes off when you start it but if the check engine light doesn’t come on then you can’t hear the fuel pump and the car won’t start just turn over
ahhh, OK, so sometimes the CEL will not turn on when it should, did not get that detail.
bad connection somewhere most likely, either connection or damaged wire or the sorts. Worst case would be an ECU issue
clc
41
Oct 19, 2017 02:27 PM
saadriaz
Jun 27, 2010 07:46 AM
