Electrical Post your Electrical issues here!
Alternator went out. What did it mess up?
Old Sep 29, 2022
Olsn8tr66's Avatar
Olsn8tr66 is an unknown quantity at this point
Title. Alternator went out. Drove it til it didn’t start like an idiot. Got it replaced. My speedometer and odometer both don’t work since then. Everything else on the dash is fine. What all could’ve got messed up when it went out?
Old Sep 30, 2022
BrotatoChip's Avatar
Super Moderator
Re: Alternator went out. What did it mess up?
Check the alternator bolts. If I were a betting man, I'd say one is loose. There's one bolt on the top, a bolt holding the mounting bracket to the block. another bolt underneath holding the alternator to the bracket (this is the one that you have to loosen in order to tighten the belt with the wingnut).
You will also want to check fuses.
Old Sep 30, 2022
Colin42's Avatar
There's wires that run right by the alternator that send the speedo and odo signal to the car
Old Sep 30, 2022
Olsn8tr66's Avatar
Checked the fuses and had to replace one. Bolts are all tight. Odometer and speedometer still don’t move. Other ideas?
Old Sep 30, 2022
Super Moderator
Just realized this is in the 6th gen and not 7th gen. I am struggling today.
Old Sep 30, 2022
Colin42's Avatar
Rupert
Dec 1, 2011 05:15 AM
treva..
Oct 19, 2008 12:32 PM
Gaza
Jul 9, 2004 09:27 PM
chefjnr
Nov 19, 2002 06:20 PM
pinkytoe
Jun 12, 2002 10:32 AM
