Electrical Post your Electrical issues here!
So I got my first question to ask
Old Dec 20, 2019
Stayyyflyyy's Avatar
Stayyyflyyy is an unknown quantity at this point
I've tested pretty much everything... Battery is charged and tested with a load on it. Passed. Starter motor and solenoid have been removed and tested with jumper wire while connected to 12 volts. Pin kicks out and spins. Placed back into car 13 volts getting to it but when I turn key nothing happens. Any ideas? Even tested alternator and its charging fine. I jumped starter motor while it was in my car and of course it starts right up
Old Dec 21, 2019
GolNat's Avatar
Prelude Owner
Re: So I got my first question to ask
Test the key cylinder.
Old Dec 21, 2019
Colin42's Avatar
Yeah ignition switch could be bad I had to do that on my 99
Old Dec 21, 2019
OK so its not my ignition switch. I used a multimeter volt meter whatever and have 12v coming from it when I turn the key but I did find the problem. Ripped up the under dash and steering column someone used speaker wire to wire up what looks to be an alarm system that never worked. Found out this relay is not clicking over for ignition. I'm somewhat learning engines and what not but electrical is not my forte yet. Can anyone tell me wth is going on here. This relay is fried but what is it connected to?
Old Dec 21, 2019
Remove starter but keep it plugged in, remove f/I fuse, try and crank, see if the starter spins?
ProStreetDriver
Aug 29, 2016 11:58 AM
Omasta81
Dec 16, 2009 09:19 PM
Omasta81
Dec 16, 2009 08:45 AM
liensaleman
Mar 21, 2007 09:42 AM
WhiteRabbit
30
Sep 24, 2006 10:21 AM
