Electrical Post your Electrical issues here!
Shift interlock problem
Old Jun 9, 2019
Pstud01's Avatar
Pstud01 is an unknown quantity at this point
2000 civic ex
Will not shift out of park
Interlock solenoid will work for split second once key is turned to "run" but will not work by pressing brake peddle.
All brake lights work.
Resistance for both wires for solenoid are good.
Anything I'm missing?...ground??
Old Jun 10, 2019
Colin42's Avatar
Re: Shift interlock problem
solenoid could be old, sticking, failing.
can try repeatedly applying power and ground to the solenoid to see if you can spot any problems
Old Jun 10, 2019
Pstud01's Avatar
Tried that even went to the local Bone yard and got another one; still won't work
Old Jun 10, 2019
Pstud01's Avatar
Testing for power at the connector when plugged into the solenoid I have 12 volts both sides but when I test at the plug Whit it unplugged from the solenoid
I only get 12 volts on the one side and ground on the other
Old Jun 11, 2019
Fault codes?
TPS voltage value is?
9812Valve
Transmission
15
Jun 14, 2021 02:24 PM
extreme58
Oct 9, 2017 06:44 AM
malcolmgrey
Feb 28, 2016 09:21 PM
crader1
Transmission
Jul 11, 2014 10:36 PM
MartinL
Aug 10, 2010 11:12 PM
