Electrical Post your Electrical issues here!
Lights turn on with engine
Old Feb 5, 2021
JednotasVlassky's Avatar
JednotasVlassky is an unknown quantity at this point
Hello everyone!
I have an ej9 1.4 d14z2 civic sedan. The previous owner(s) installed something to automatically power the headlights when the engine is turned on bypassing the light switch. This wouldn't be a problem, if I could turn the high beams and the praking lights on. The high beams work if I pull the lever towards me, but they don't stay on.
In the book I have found a paper with instructions for something like this: https://www.speedtech.sk/product/546...tiel-uni-se085
I have taken the bottom panel off from under the dash and also the steering column cover, but haven't found anything. Obviously I don't know what to look for exactly, I'm 18 years old and I don't have any experience with electrical wiring in a real car, only Arduino RC cars.
I could provide some pictures if needed.
Thanks a lot!
Old Feb 5, 2021
Re: Lights turn on with engine
pulling the lever is typically momentary-on high beam (e.g. flash to pass). Pushing the lever away from you (forward with respect to the vehicle) is typically constant-on mode for high beams
Old Feb 5, 2021
BrotatoChip's Avatar
Super Moderator
Also, the headlight switch has to be on in order for the high beams to work by pushing the stick away from you. The flash to pass will still work with the headlight switch off.
Old Feb 5, 2021
aftermarket DRL (Daytime running lights) are typically on the engine bay. Look closer tot he battery.
They are intended to turn the high beams at half the power, so makes sense the high beams are affected
Old Feb 5, 2021
Thanks for the replies.
I thought about trying turning the switch on and then try the high beams but I didn't want to turn on the engine for that. I knew it would solve it, but the main thing is the parking lights.
I've found the black box that controls this.
The first one is that thick red wire, which is connected to the fuse box via two 10Ampere fuses (I think..I'll include the picture later). Number two is a red one that is next to a black one which goes into the headliner. The third is connected to the circuit in the box. These three are connected. The fourth, brown is the ground.
This is that first wire
And this is where it is connected
Now to the wires that leave the controller, or whatever it's called:
This was in that slot in the background, it has five pins: (from left to right then second row from left to right(from the wire's side as you see now)) [1,0,X,2;3,4,0,5]
[1,0,x,2;3,4,0,5] Number 1 - red and blue, hasn't been touched
Number 2 - red, it has been cut than connected, but seems like they maybe cut the wrong one and re-connected it.
Number 3 - red and white, connected with yellow and green wire, which is for low beam and high beam, it says in the diagram.
Number 4 - white, it is connnected with the original white that comes from a loom(I hope this is the right word) with even more wires, and a red from the box itself. For power I guess.
And number 5 - red and green, this is paired with a black and grey for the right side parking light that also comes from the box
But the left side is nowhere to be seen. It is wrapped up with a red and grey which is for the left side and one other wire for disabling the whole thing, but it seems like they haven't done a great job and all they cared about was the daytime running light and not about not blinding other people in the parking lot. So I'm guessing this is the problem.
Although I don't know what this connector is actually for, and as I've mentioned before, I don't really know what to look for.
I hope you understood my point and mainly my English. Thanks again.
Dhillon2012
Nov 27, 2013 07:08 AM
ccook
Mar 13, 2010 04:26 PM
sibotak
Electrical
Apr 22, 2007 01:35 AM
Scott Civic
Lighting
18
Feb 6, 2007 12:03 PM
Anathema
Sep 11, 2006 04:49 PM
