Electrical Post your Electrical issues here!
Instrument Cluster and Driver Side Speaker Issue [solved]
Old May 23, 2024
coachroy's Avatar
coachroy is an unknown quantity at this point
Well this is new. I inherited this problem when I bought the car. 2000 Civic Si SOHC 1.6L Manual. I just found out when the driver side door speaker is installed, it blows #30 Light Instrument Fuse. Has anyone come across this before? I'm not even sure where to begin metering or what I'm metering for haha.
Old May 23, 2024
Colin42's Avatar
re: Instrument Cluster and Driver Side Speaker Issue [solved]
Check the stereo wiring in the dash. That's the only spot i can think of where those wires would be close together
Old May 24, 2024
coachroy's Avatar
So out of pure luck, I figured it out. I was switching out the instrument panel light bulbs with LED bulbs and when I finished< i was reinstalling my radio bezel back in and all of a sudden the lights went out and I heard the fuse pop. I was actually pretty happy because that really narrowed down the area of cause. I put a new fuse in and played around with some of the harness and pop goes the fuse again. I start inspecting the harness ive narrowed it down too and there was 2 wires that were part of the radio harness that were cut and not taped off. These were shorting out and causing the fuse to pop. I taped them up and I now have working lights on my cluster and I have my driver door speaker working again. If only I can get this stupid SRS light to reset now.
Old May 24, 2024
Colin42's Avatar
Glad you found the issue, might just be worth going to a shop to get the light reset. If you went to an independent guy and asked nicely they might do it pretty cheap
36racin
Electronics
Feb 19, 2023 02:57 PM
Sayword90
Electrical
Jun 8, 2020 06:59 PM
CivicEX2OO2
Nov 16, 2010 12:40 PM
