Electrical Post your Electrical issues here!
Horn wire
Old Jan 27, 2021
Vepy's Avatar
Noobie
Vepy is an unknown quantity at this point
Horn wire
How would I take the stock horn wiring harness and split it so it hooks up to a horn with a negative and positive terminal? Or would I have to get one with just a single pin?
2000 Honda Civic Ex
Old Jan 27, 2021
Re: Horn wire
2 pack of single to single adapters: https://www.collegehillshonda.com/20...rket/0S03.html
Single to dual horn adapter: https://www.collegehillshonda.com/20...ket/0S03A.html
Either one will work, even if you're only going from oem single to aftermarket single horn. Most people do a single to dual horn conversion to get rid of the wimpy "meep keep" sound, at least in my observation
Old Jan 27, 2021
Vepy's Avatar
Noobie
Re: Horn wire
Thank you! I couldn't find any adapters online/Amazon, just ordered it and hopefully everything goes smoothly
Old Jan 27, 2021
Re: Horn wire
I did the same-ish for my 2018. 10th gens have a different connect, but collegehillshonda had an adapter for it.
Here's the DIY I did for the 10thgen. The procedure for any other gen will be just about the same
https://www.civicforums.com/forums/2...horn-swap.html
Old Feb 5, 2021
Vepy's Avatar
Noobie
Re: Horn wire
I ended up buying the single to double adapter, but couldn't figure out how to get it working after connecting everything, Am I supposed to connect the "minus earth" to the car's body as a ground, or connect it to the negative battery terminal?
Old Feb 5, 2021
Re: Horn wire
I mean, technically either. I would just ground to chassis. You doing a single horn or dual horn setup? I can make a quick and dirty wiring diagram for you
Old Feb 6, 2021
Vepy's Avatar
Noobie
Re: Horn wire
I'm doing a dual horn setup, I just did a quick test by holding it to the car's frame to see if it came on, and it didn't seem to work
Old Feb 8, 2021
Colin42's Avatar
Re: Horn wire
Was it bare metal? Electricity doesn't travel through paint
thetexan
May 2, 2017 02:30 PM
CreativeRider
Aug 13, 2009 03:22 PM
EM2 Nig
May 21, 2006 01:01 PM
LAKAS187
Feb 8, 2004 02:47 AM
hondafan
Mar 8, 2002 07:46 PM
