Horn honk help
Horn honk help
Ok guy's I need your help. how do i wire up my alarm for it to honk both the horn
and the siren?My alarm has an output for both of them. The output for the horn
is negative, i have tried wiring the horn using relay's,direct wiring and none of these
methods work. I'am not a newbie at installing car alarms but this just leaves me
puzzled
I know that the horn wire is located in the steering
column and that it's a (-)negative orange wire, but why do 3 orange wire's just become 1???
here's a link to my alarm's wiring diagram.
wiring diagram
It's pg.27 of 27
Any help is greatly appreciated.
puzzled
I know that the horn wire is located in the steering column and that it's a (-)negative orange wire, but why do 3 orange wire's just become 1???
wiring diagram
It's pg.27 of 27
all i can say is make sure you have the right wire and make sure its ground. i couldve sworn it was positive, otherwise you might have just blown a fuse...double check and make sure your horn is still working..i dont see why a relay wouldnt work. test for your wire and then hold it to ground and see if you can make it honk that way..
MamaBear2015
Sep 24, 2015 11:34 AM
18
Aug 17, 2015 08:02 AM
