Electrical Post your Electrical issues here!
Obd isnt reading
Old Sep 2, 2020
Nekowem's Avatar
Nekowem is an unknown quantity at this point
Obd isnt reading
So I took my 98 ek to emissions today and when he plugged in my OBD nothing came up the screen was black (his reader wasn’t Bluetooth) my acc/cigarette fuse is replaced and good anybody know what it could be?
Old Sep 2, 2020
BrotatoChip's Avatar
Super Moderator
Re: Obd isnt reading
Have you verified power/ground in the OBD connector? Pins 4/5 should have ground, pin 16 should have battery voltage.
Old Sep 2, 2020
Nekowem's Avatar
Yeah I tested pins 4/5 with a light test for power and got nothing than took a digital multimeter to check for power on 16/4 and still got nothing. My OBD isn’t getting power at all
Old Sep 2, 2020
Colin42's Avatar
Check for any other blown fuses, follow the wires back to see if they're damaged
Old Sep 3, 2020
Super Moderator
What? Of course you won't have power on pins 4 or 5, they are ground. Take one probe of your meter and go in pin 16, put the other in pin 4. That should give you battery voltage. If not, check fuse 43 (7.5 A) in the under-hood fuse box.
fcs
Electrical
Sep 1, 2020 07:30 PM
Rush
May 18, 2018 09:49 PM
desmond4890
Oct 18, 2016 12:12 AM
diggaflip
Lighting
Mar 2, 2005 04:19 PM
Vinh
Aug 31, 2003 07:24 AM
