Electrical Post information/questions/Issues about Electric parts here.
which fuse for OBD port
Old Dec 22, 2014
fcs's Avatar
fcs
fcs is an unknown quantity at this point
I went to get my emissions test today and the tech said he couldn't get power on the OBD port. I got the same thing later with my scan tool. Which fuse is it on? If its on the same fuse as the ACC socket then the problem must be bigger, because the cell phone charger works. This is a 2006 LX.
Old Dec 22, 2014
Re: which fuse for OBD port
couldn't get power on the OBD port. Which fuse is it on?
The blown one.
It is not.
Check fuse #23 in the engine compartment
Old Dec 23, 2014
fcs's Avatar
fcs
Fuse 23 (the one helpfully labeled "Backup") is fine, along with all the other little fuses under the hood. I looked at the ODB connector and what I can see (not much) looks OK. So I guess its to the dealer I go.
Old Dec 23, 2014
Dig out your voltmeter. This is the connector view as you stare into the open side (opposite the wires)
Pins 4 and 5 are grounds
Pin 16 is power from that fuse.
All the rest are for the computers and communication so don't mess with them
Old Jan 15, 2015
fcs's Avatar
fcs
Thanks for the advise, Ezone.
Just thought I would close thread this out. After contorting my senior citizen body under the dash my voltmeter showed 12.6 volts or something. Holiday travel postponed further investigation, and when I took the car to a different shop for a retry at the emissions test, everything was fine. So either it was a transitory problem with my ODB system, or a problem with the equipment at the first test station.
Old Sep 1, 2020
Nekowem's Avatar
Nekowem is an unknown quantity at this point
. What was the problem?? I have the same exact problem my obd isn’t reading and I can’t figure it out please help!!
burnyd
ECU Fried
May 24, 2018 10:44 PM
JetsterDajet
Aug 16, 2015 01:56 PM
Dave1984
Jul 22, 2015 06:10 PM
Civic65
Jul 19, 2015 10:13 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
