Electrical Post your Electrical issues here!
Speedometer not working, help?
Old May 23, 2020
Mason Petty's Avatar
Mason Petty is an unknown quantity at this point
I bought a 1996 Honda Civic dx 2 door coupe. The speedometer doesn’t work. I replaced the speed sensor but it still doesn’t work. Any suggestions?
Old May 23, 2020
Colin42's Avatar
Re: Speedometer not working, help?
There's a tsb about the wire harness for that sensor getting chewed up by the belts. Backside of the engine near the top
Old May 23, 2020
Thank you, I will have to check that. Any reason that both o2 sensors are causing a check engine light?
Old May 23, 2020
Colin42's Avatar
They could both be bad? What codes are you getting? Pxxxx format.
May want to check the wiring harnesses for damage considering you have the issue with the speedo
Old May 23, 2020
Im getting 4 codes, Po135, Po501, P1298, Po141
Old May 23, 2020
Colin42's Avatar
P0135: check the wiring but the sensor is probably bad, buy Denso or ntk, nothing else
P0501: check the wiring as I mentioned earlier, what brand was the new sensor that you put in? Do you still have the old one?
P1298: could be the wiring, could be a bad eld
​​​​​​​P0141: check the wiring but the sensor is probably bad, buy Denso or ntk, nothing else
Old May 23, 2020
Okay, thank you
Old May 24, 2020
This.
frederickhsu
Apr 8, 2017 07:41 PM
lindylex
Aug 5, 2014 12:30 PM
JEFFROETIP
Jun 21, 2012 11:51 AM
thall8
Dec 1, 2011 02:17 PM
ryrex02
Dec 22, 2010 09:03 PM
