Speedometer Not Working!
Old Nov 22, 2011
thall8's Avatar
thall8 is an unknown quantity at this point
So i was driving down the road about a week ago in my 01 ex 5sp, and the speedometer just quit working, went to and stayed on 0. Took the car to O'reillys and 0bd2 reader threw a code for the vehicle speed sensor. Went to Honda and bought part, replaced it myself, and the speedo still isn't working The code is still being thrown and i have no clue where to go from here. All help appreciated!
Old Dec 1, 2011
thall8's Avatar
Re: Speedometer Not Working!
so i took it to pb honda of kingsport tn, and after 3 hours of labor, told me my speed sensor was fine. and that it was an electrical problem. they charge 79 an hour, so if anyone could try to steer me in the right direction it would be much appreciated. also, my odometer isn't moving either, it's stuck on 179371 ):
Old Dec 1, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Try cleaning the battery terminals, disconnecting it might reset the speedometer, I would check your cables and make sure one did not fall off and make sure they are on right, I do beleive there is a cable under the car that connects to the tranny. did you check the fuses? that would be a good place to start too.
Old Dec 1, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
I would also make sure your getting a good connection at the vss. Those plugs can get wet and corode.
izdman
May 19, 2015 03:43 PM
Chronic_issues
May 8, 2015 05:40 PM
ORskier
May 3, 2015 12:54 PM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
