Electrical Post your Electrical issues here!
'96 Civic no crank, no headlights
Old Sep 7, 2021
Tim Keith's Avatar
Tim Keith is an unknown quantity at this point
My '96 Civic has been parked for 3 months, but now has no crank, no headlights. Only the horn works
I charged the battery and cleaned the battery posts and used a multimeter to determine that there is 12.6 volts at the cables and that the voltage from the positive battery post to chassis ground is 12.6 volts. The fuses next to the battery are ok.
EDIT: from the starter positive post to the chassis ground is 12.6 volts.
Tim
Old Sep 7, 2021
Re: '96 Civic no crank, no headlights
check fuses next
under the hood
not winter and warm engine so that they will try to get under the hood, but do check for rodents chewing wires too
Old Sep 7, 2021
Tim Keith's Avatar
The fuses next to the battery test ok. The 80 amp power distribution circuit has 12.6 volts but the headlight switch circuit fuse has no voltage. The ignition circuit fuse has no voltage but I think that depends upon the key being in the 'on' position.
Old Sep 7, 2021
oh, sorry, i missed that you checked fuses on your first post...
i would then go for a starter?
smack it a few times, sometimes the solenoid gets stuck
be gentle if this is her first spanking
Old Sep 7, 2021
Tim Keith's Avatar
The headlight fuse #48 should be hot at all times, but it has no power. The ignition fuse #42 should also be hot at all times but have no power
Again the power distribution fuse #41 is good and has 12.6 volts.
Old Sep 8, 2021
your wiring is likely damaged?
Old Sep 8, 2021
Tim Keith's Avatar
According to the attached diagram #41 (power distribution fuse) directly flows to #48 (headlight fuse) inside the underhood fuse box, but that isn't happening on my Civic.
Old Sep 8, 2021
Tim Keith's Avatar
I removed the bottom of the fuse box. Looks like water damage. I might be able to clean it up. I had parked the Civic under a tree, looks like leaves built up a dam and caused water from the windshield to flow into the fuse box. Pretty nasty looking. I think this is the problem.
Old Sep 8, 2021
Tim Keith's Avatar
I cleaned the connectors on the bottom of the fuse box and now have interior lights and turn signals. I'm still not getting continuity to the headlights and ignition fuses. There is a voltage drain as the battery is nearly discharged. Can I cut the fuse box open to clean inside? Or should I just buy a used fuse box?
Old Sep 8, 2021
car-part.com for nearby scrapyards
Old Sep 8, 2021
Colin42's Avatar
Probably only like $30 for another fuse box
Cex02
Electrical
Jan 19, 2020 08:24 PM
R3KogHyZe
Feb 9, 2016 09:24 AM
Mitchell Sims
Dec 19, 2015 11:34 AM
Mike Garvey
Jun 7, 2015 07:25 PM
mah81
15
Feb 16, 2010 09:04 AM
