Electrical Post your Electrical issues here!
Engine Management Light on
Old Mar 7, 2013
CHAB's Avatar
CHAB is an unknown quantity at this point
Desperately need help with Honda Civic Sport (2000)
Charge light not coming on, lights pulsing, alternator apparently not charging, although reconditioned one fitted, and have tried three now! Charge light bulb ok, wiring ok, speedo jumping about. Have renewed all earths to engine etc. Engine running rough at low revs.
Any help much appreciated!!
Old Mar 7, 2013
mikey1's Avatar
Re: Engine Management Light on
check and make sure all the alternator bolts are tight and TORQUED PROPERLY TO SPECS.....also make sure the alt belt is tight
Old Mar 7, 2013
CHAB's Avatar
Thanks, have done, no change!!
Old Mar 7, 2013
04 Honda Civic's Avatar
Check the battery under load?
Did you tighten the alternator belt?
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Readypro
May 2, 2015 12:23 AM
F1wanabe
Apr 27, 2015 11:06 PM
supercivic01
South
Nov 30, 2001 11:27 AM
