Electrical Post your Electrical issues here!
Problem with fuse for fuel pump
Old Jun 22, 2023
Jo-Jo's Avatar
Jo-Jo is an unknown quantity at this point
Hi there
I have a 1998 Honda Civic which is a great car but in the warm months, has a problem with the immobiliser cutting off fuel. I've had 3 things changed - fuel pump, alternator leads and some little red box thing(sorry, I'm no mechanic!). Same issue continuing. As an easy possibility, I'm now looking at fuses. The one for the fuel pump is an unmarked black one and pushed further in than the rest - I can't remove it so am wondering if this is meant to be like it or perhaps this is finally what the problem is? Be great to have some advice. Thanks.
Old Jun 22, 2023
Re: Problem with fuse for fuel pump
there are no immobilizer on this car generation?
you need to check if there is no damage to wires, bad terminals or connections or splices in older cars. Can even be rodents chewing wires.
test for continuity using a multimeter
Old Jun 22, 2023
Colin42's Avatar
Photos would be helpful
Old Jun 23, 2023
Jo-Jo's Avatar
Thanks very much for advice. Definitely has an immobiliser - green light with key sign. I'll check wires etc as you suggest. Cheers
Old Jun 23, 2023
ah, I see you are in GB...
my statement was for Americas.
instead of replacing fuel pump, you should have tested it.
Because if the green key is flashing, what is stopping the pump is the immobilizer.
you need to troubleshoot the immobilizer, and it is from key to reader in ignition and the wiring to the immobilizer. And the immobilizer itself (ECU?)
Old Jun 23, 2023
Jo-Jo's Avatar
Yes, I thought immobiliser from the word go and am convinced that's the root of the issue but my mechanic (a honda specialist) didn't!!! I've managed to work out how to deal with it over last couple of years but when the weather's hot it's worse and it plays up all the time - left for a few hours it starts with no issue whatsoever - it was fine over the winter but really playing up this summer!
etgo
Jun 5, 2021 02:19 AM
crazyone64
General
Apr 16, 2019 12:52 PM
boostem2
Jan 20, 2013 03:27 PM
d17lpower03
Engine Swaps
Aug 24, 2004 08:11 AM
kezay
Aug 4, 2004 07:20 AM
