Electrical Post your Electrical issues here!
ABS light if RPM more than 2500
Old Aug 13, 2023
recor's Avatar
recor is an unknown quantity at this point
1997 Civic EX, manual, 147k miles. My ABS light started coming on when my RPMs exceed 2500. It will go off once it goes lower. It's not generating any codes. I've read the ABS module is sensitive to voltage - could this be an alternator issue at high RPM? Battery is fine, drives fine otherwise so far.
Old Aug 13, 2023
Colin42's Avatar
Re: ABS light if RPM more than 2500
Whats battery voltage when the engine is at 2500rpm?
Old Aug 13, 2023
recor's Avatar
When running with lights/AC/stereo at idle, it was 13.6-14.5v at various points.
When revving up to 2500+ in neutral, it hit 17.2v, though the ABS light didn't come on. Not sure if the light would be affected by being in neutral in my garage.
Old Aug 13, 2023
Colin42's Avatar
17v is bad, it should never go above 15v. Need a new alternator. Do not buy aftermarket, oe, new or from a junkyard. I think the oe supplier is mistubishi, might be denso. See if you can read the sticker on yours
Old Aug 13, 2023
recor's Avatar
That's outside my ability, so it would be a shop job. Mine was replaced 4 years ago with a remanufactured one. Guess I'll keep the RPMs low until I can get it in somewhere.
Old Aug 13, 2023
overcharging likely gonna make more damage
Mevett616
Electrical
Apr 14, 2020 04:45 PM
Fernando559
Mar 14, 2018 11:37 PM
rpewing
Nov 19, 2013 12:45 PM
Matty1321
Jan 17, 2011 09:31 PM
supyo923
Oct 9, 2010 11:04 AM
