Battery light on in idle
Old Oct 6, 2010
supyo923's Avatar
supyo923 is an unknown quantity at this point
I have an 02 EX. It recently died, got the battery replaced just in case, then it died again. Took it to a shop and they replaced the connectors. Tested the alternator just in case but they told me it was fine.
Now, 3 weeks later, the battery light is going on every time the car is in neutral with no RPMs. If I leave it in neutral and gas it, the light goes off. On my way home, the SRS and ABS lights also went on and stayed on. Seems my lights are dimmer. Haven't tried to restart it yet.
Based on other posts, I'm worried it's the alternator. However, that seems strange since I just got it checked.
Ideas?
Old Oct 9, 2010
Kevinkriz's Avatar
Kevinkriz is an unknown quantity at this point
Re: Battery light on in idle
Something is wrong in the charging circuit, so it's not necessarily the alternator. Check the voltage regulator.
Old Oct 9, 2010
Kennykid2002's Avatar
Kenny the Ricer
Yep, some reason it's not charging correctly
Check your grounds as well, and your Alternator-Battery fuse in ur fuse box
Old Oct 9, 2010
have you checked the charging voltage at idle at the battery? alot of times an alternator can test "good" meaning it produces amps, but it can only be producing 30 amps instead of 65amps and there is your problem. this weak alternator must be working at its best otherwise the car will not have enough power to function. get it tested again at a place you know can read the equipment and not just say its fine. is your engine light also on?
Old Oct 9, 2010
BigD001's Avatar
BigD001 can only hope to improve
Sorry to thread jack maybe someone here can help me? Last week i hit a bump hard and two days battery dies on me and the engine light and battery light is on,so took it in was told it that the alternator was bad bought a new one and battery hooked them up and still no charge coming from the alternator and lights are still on. do you know whats causing this. Also good to see ur still on here gearbox
CarStuff
Dec 6, 2020 12:52 PM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
