- Axle rubbing
- Help Needed: Upgrading Suspension on My EK4 Civic!
- Suspension parts
- Honda Civic EX 2000, Suspension
- totally noob here, first honda civic ever.
- Raceland Coilover install.
- Suspension help!
- Honda civic ek3 stock ride height
- Rear Control Arms, Hatch/Sedan same?
- suspension and brake conversion
- Maxpeeding Coilover help
- Rear coilovers fork bolt size
- GC coilover ride quality
- Suspension for a stance build
- Good springs?
- Installed lowering springs and now the front end isn't level?
- What are these parts called
- Coilover suggestions?
- ‘00 EJ8 coupe rear suspension components
- 99 civic front camber
- EM1 - Looking for parts
- Suspension On 4WD CIVIC
- Shocks/Struts/Coil-over... that is the question.
- Help please
- Rear Toe Question
- Brace vs Bar
- Front Suspension Inspection and or Maintenance
- Blown strut mount??
- Suspensión problem plz help
- Em1 Rear Trailing Arm
- DNA motoring coilovers?
- Interchangeable parts for 99 SI
- rear suspension lowering
- Monroe shocks/struts
- Advice on Lowering springs.
- OEM dust cover?/ground control with koni
- 2000 Civic Sedan LX - manufacturer specs for ride height?
- Ground Control Coils + Eibach Springs
- One side lower than the other
- Has anyone used SENSEN shocks/struts?
- Em1 tein street basis coilover
- Struts on 2000 ex
- Junkyard Suspension Build
- Coilovers for Civic.
- Lowering advice
- EM1 Question- TEIN Coilovers "Won't Fit"?
- Left Front Shock Knocks During Full Lock Turns
- 98 dx struts
- EJ8 sedan suspension HELP!!?
- Post pics of your 6th gen Civic with a 2 inch drop
- Rear suspension issues
- Smooth Suspension w/ Very Low Clearance.
- New Here. Right front wheel noise.
- Suspension Setup Question
- Strut Mounting Washer Question
- Ingalls Rear Camber Kit
- Help returning race car to rider
- 1998 civic hatch
- What's the problem here. Car sitting low.
- ebay "coilovers"
- New here, coilover set up for 4dr 96ek?
- Coilover question
- Rsx sway on 2000 coupe bolt up?
- Spoon Springs EK9 Dampers
- Cheap suspension- how cheap should I go? What should I avoid?
- Front sway bar help
- Worth of my used coilovers?
- Eibach Sportline Plus Kit
- Lowering Springs Issues
- Stock tower bar
- Sway bars
- Adjusting suspension.
- Replacing TAB what else should go?
- I need help asap! Please!!
- 2000 Civic EX Coupe Lowering Questions
- Coilover decision
- lowering springs
- H&R coilovers stuck can't raise them
- 99 Civic Adjustable Springs suggestions? plz
- Cheap quick struts on ebay
- Un-lower a 2000 ex? Help please
- Help Me Setup My Road Race (Track) Suspension
- front suspension too low
- In need of a 2 inch drop, what springs do you suggest? 96 hatch!
- Rear Suspension problem on 1999 SI
- 1998 Honda Civic CX Hatchback Suspension
- 17×7 on a Ek Hatch
- few questions on where to start on car!
- 2000 Civic LX Eibach Pro-kit review + links to DIY for you guys :)
- Help identifying part # - front LCA
- Front Strut problem
- need new shocks... suggestions?
- Stock 1997 Civic wears tires on edge?
- lowering springs
- Suspension help: coil overs or lowering springs?
- need help with suspension setup
- Help with first suspension setup
- im getting fustrated...99 ek hatch...suspension
- coilovers
- drop now or later?
- Want my car to look like this
- Struts for S Techs??
- Recommendations
- Are these adjustable coil-overs or at least adjustable?
- Lowering choices!??
- Need help do I have adjustable springs or coil overs ( pics inside)
- any recommends on coilovers for 96 civic hatch?
- Seized coilovers
- How to raise my coilover racing suspension?
- Delete this thread.
- 1998 new front shocks
- Suspension help.
- Best shocks for ebay coilovers.
- Rear Sway bar; only bolted to subframe on left side..
- Recomendations for new coilovers?
- Does lowered equal harsher ride???
- Lowered on OEM shocks...
- A Little Assistance?
- 97 civic suspension problem... need Help ASAP (pics inside)
- Can u answer this? (pics inside)
- Wheel spacer problems
- Looking for some help with coils.
- new kyb rear struts
- In a Predicament...
- eibach prokit and KYB GR-2 setup, what parts do I need to complete setup?
- Need Help Deciding..
- How low can I go?
- Coilover Opinions?
- 2000 honda civic dx...need help installing coilovers!
- Hx vs Ex vs Si suspension
- Moog Bushing for Trailing Arm
- my suspension setup
- can the stock suspension's camber angle be adjusted? (1.5 degrees toe out)
- 99 Civic EX Trailing Arm Bushing
- another sway bar thread
- fixing my suspension
- are springs and struts the same
- i need help 98 civic lowering question
- 6th gen suspension setups
- New member, new honda owner
- lowered with 15" wheels
- 98 Civic, Help me out?
- Spring rate and sway bar reference
- Pillow mounts - Got to have em or nice thing to have?
- D2 Racing RS Full Coilovers - Anyone got these?
- Rear left sits lower than right...
- Rear left lower and dragging... but not any more?..
- Suspension shops in Houston, Tx
- What are good racing seats?
- Suspension trouble--help a newb out :)
- Help on lowering 96 civic ex
- Suspension Question
- Help a newb?
- Need info on lowering?
- Function Form Type 1 Full Coilovers + Blox Full Camber Kit
- Suspension Problem please help!!!
- squeaks from rear end
- 99 DX Hatch Suspension Upgrade Time
- Who Know's What?
- Broken suspension bolt
- Quick struts or get just the strut
- sway and strut bars
- GSR rear sway bar??
- 97 ex civic suspension help
- Hi everyone, need advice
- what is the best strut coil combo?
- Lower Ball Joint Replacement Question...
- Tie Rod Question
- Replaced l-ball joint, what about the upper?
- 98 honda civic ex coupe lowered
- average lat g
- 1997 civic dx rear brake swap
- How do I fix cut springs?
- APX Shocks?? for oem replacement
- I think my stock shocks are bad, suggestions?
- Pinch bolt?
- Engine mounts
- air struts or air ride em1
- 97 hatch suggestion
- Slamming a Colorado Car...?
- Question on lowering 96ex coupe
- Suspension brand comparison/suggestions!
- need better suspension for all the wieght in my trunk
- 99 Honda Civic SiR/EM1 suspension q's
- Knocking Sounds on Civic 97
- 99' SI Coilover replacement
- Coilover and camber help
- 99 civic progress coilovers?
- Suspension 98 ek coupe
- Camber Question
- Will Koni Yellow Shocks & Coilovers for90-97accod fits on 2000 honda civic hatchback
- Scraping and grinding noise in the back. Please help!
- Ride height is uneven
- Lowered car....... makor camber issues HELP
- Help! 2000 Civic Suspension ?
- Lowering spring install
- FCP Import Suspension Kit
- suspension "clunking"
- Civic 96 Manual Steering Tie Rods
- Noob looking for some suspension info
- outta nowhere!!!! i need help asap
- Great deal on Vogtland Springs
- lowering springs on 99 honda civic
- help
- 98 civic wheels rub inner quarter panel
- plz help anyone from central pa
- lowering 97 civic
- Suspension
- Coilovers: I need to no how to install
- spring and shocks from a 91 fit a 96 civic?
- Squeaky suspension--what is it?
- suspension help
- 99 hatch suspension questions
- Chassis Compatibility Question
- Noob question about lowering
- Civic SI springs for Civic EX ?
- Shocks Bottoming Out w/Coil Spring Spacer
- coilover installation?
- 98 civic lowering
- 96 civic suspension
- Whats the difference between Tanabe Pro SS and S-0C
- Axel for 97 civic with swapped engine
- Suspension package advice
- Rear discs
- 2000 Civic Front Ball Joint Replacement!
- Coilover Rebuild Cycle
- 97 Civic Suspension any suggestions?
- Need info on Progress Springs for '00 Si
- cheap lowering
- 97 coupe need lowering advice
- Help Help Help...
- Advice please
- suspension help
- What's consider a "very low drop"
- ES bushings worth it?
- New springs knicked(unistalled)...is this bad?
- Civic 00 Stock to Mod suspension ?
- wich supension i should put?
- Suspension drop pics suggestion
- Different Struts/Springs on the civic
- After lowering are the stock shocks...
- Did an accident throw my alignment?
- Neuspeed springs wear on my tires
- Monroe Struts Good or Bad ?
- suspension help request
- Front ball joints
- What is the camber kit to civic 2000 lx?
- Can suspension problems cause this?
- Unknown Drop Kit
- best ride for 98 civic
