Camber Question
Old Jul 9, 2010
brandonparsons's Avatar
brandonparsons is an unknown quantity at this point
Camber Question
Anyone know whats a good camber setting for the front and back wheels for the best traction?
Old Jul 9, 2010
02civicsi02's Avatar
Low and slow!
Re: Camber Question
I would say 0 since that is where it is at the first place I think if I am not wrong.
Old Jul 10, 2010
Re: Camber Question
do you mean traction at corners or forward? What do you use the car for?
If autoX, the most camber you can get without loosing too much acceleration and braking, daily driving just keep stock, road racing uses less than autoX.
Old Aug 8, 2010
Re: Camber Question
Originally Posted by clyde dove
You Should Know:------>
Camber is the second most important angle/measurement that results in tire wear (Toe-in is the first). If you de-camber the car, and lower it, you will certainly cause uneven tire wear, and additionally cause handling problems beyond what you will incur as a result of lowering the car.
If you have particularly wide tires, the more off-zero you go, either positive or negative, the more tire wear and instability you will experience.
I even the wear everytime i do an auto-X, so do not matter much. One autoX and the outside will wear much more than a month dailydirving of 30 miles both ways.
GolNat
Jan 12, 2021 09:06 PM
naokigoffi
Aug 30, 2015 06:19 PM
martinsmartin
Aug 15, 2015 07:34 PM
