H&R coilovers stuck can't raise them
Old Oct 17, 2013
newtocivic11's Avatar
Chris doesn't know
newtocivic11 is an unknown quantity at this point
Ok so I am new to civics but have a 600 hp wrx with coilover as well and they adjust very easily. Ok so I took the wheels off and have the wrenches to adjust everything. But these mo fo's are seized on there I am wondering if there is anything that I need to loosen besides the lower locking nut. I put pb blaster on it to see if it would free it and it hasnt. Do I need to loosen the suspension from the top mountin point so the coil can spin. I have Tiens on my subaru and they adjust so much easier than these H&R's if anyone can help please do.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: H&R coilovers stuck can't raise them
Cheap coilovers + road salt + moisture = seizure.. Removing them might make it harder as they will try to spin while your doing it. He is pretty much stuck at the height it's set at.
Old Oct 17, 2013
GolNat's Avatar
Prelude Owner
Freeze spray may help in getting it loose.
Or a little heat and then freeze.
Old Oct 17, 2013
rustycivic's Avatar
rustycivic is on a distinguished road
Since when are H&Rs cheap?
But heat, and freeze, combined with liberal amounts of PB Blaster should do the trick, if not, see if a shop can do something about it.
Old Oct 17, 2013
BlueEM2's Avatar
Whachya lookin at?
Didn't check to be honest. I don't know much about 6th gen civics and HNR don't offer (from what I know) for the 7th gen. But if they are seizing they obviously aren't that good.
Tedverseti
Apr 23, 2020 01:45 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
GolNat
Nov 27, 2018 03:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Tedverseti
Sep 29, 2015 05:41 PM
