Function Form Type 1 Full Coilovers + Blox Full Camber Kit
Old Jul 21, 2011
AJgrewal's Avatar
AJgrewal is an unknown quantity at this point
So I can get a FF Type 1 Full Coilover kit for $630 on eBay and a full (front & rear) Blox camber kit for $230 from weaksauce.
That sounds like a complete suspension setup for $860. What do you guys think about this setup?
It says that FF Type 1s don't come with dampening control, what's that?
I don't want uneven tire wear and I don't want something super expensive. I want a 2 inch drop on a 99 SI with no headaches.
Will I be good to go once I throw on these coils and camber kit?
EDIT: Posted this on the wrong forum, sorry guys...
Old Jul 22, 2011
lowlife9's Avatar
Re: Function Form Type 1 Full Coilovers + Blox Full Camber Kit
you can get those for $599 free shipping here http://www.robearracing.com/pd-funct...ivic-96-00.cfm and robear can be trusted more then an ebay seller
but i would rather have these on my car http://www.robearracing.com/pd-progr...ic-integra.cfm
Old Jul 22, 2011
maxtierney's Avatar
EM2ti
Non-adjustable dampening isn't the end of the world. Most non-damps are set on the softer side, in order to please those wanting comfort over handling dynamics. Most people who have adjustable dampening, set it once, and leave it alone.
With most coilovers or shocks, dampening is adjustable for the compression and not the rebound. Which isn't the best scenario for good handling. Basically, compression dampening controls the upward movement of the shock, and to reduce the resulting spring vibration. Typically, a soft compression setting allows the piston in the shock to move up quickly and absorb the impact when your tire hits a bump. Of course, this is good for most daily driving applications. However, what comes up must go down. That quick upward travel of the piston, means quick downward travel too. That's why you see cars porpoising on the freeway, wheel hop on heavy acceleration, loss of traction, etc. With adjustables, the rebound can be set to slow the piston movement and reduce this effect. But that comes with a cost too. If the compression rebound is too stiff, your shock's "absorbtion" abiility diminishes, resulting in a harsh ride. Only the more expensive sets offer seperate rebound dampening. This allows for fast piston travel upwards (compression) with slower piston travel downwards (rebound) and optimal ride. Some companies try to overcome not having rebound settings with tapered holes, different oil viscosities, magnetic particles, etc. But thats another topic.
Old Jul 22, 2011
MindBomber's Avatar
Live for the Twisties
Just like Max put so well, dampening adjustment is't the end of the world. If you have a very heavily modified suspension and you autox routinely you might miss it, but otherwise you'll never realize it's not there.
Moved to 6th gen.
Old Jul 22, 2011
AJgrewal's Avatar
Everybody is recommending the Progress CS-IIs and since they're a wee bit cheaper than the FFs, I'm not one to argue.
Would I need a camber kit for a 2 inch drop? I'm tempted to just buy the CS-IIs right now and throw them on my EM1.
Old Jul 22, 2011
MindBomber's Avatar
For a 2'' drop, yes.
For a 1.5'' drop, no.
Old Jul 22, 2011
AJgrewal's Avatar
Any recommendations for a camber kit? I'm definitely going 2".
Old Aug 24, 2011
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
I have some CSII coming in VERY soon.
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
duyaknow
Nov 23, 2001 07:28 PM
SneakerPimp
Nov 3, 2001 10:57 AM
ImmortalEX
Oct 31, 2001 10:00 PM
