Help returning race car to rider
2000 Si with H&R coilover Koni sport struts, ride height not adj. now have new Megan coilovers that are adjustable. How do I set the initial preload on all 4 and should they be set the same?? Son wants ride height higher with a softer ride.
Re: Help returning race car to rider
Megan coilovers are not the best thing if he wants it raised and a softer ride. The spring rates on coilovers are higher then lowering springs. The car will be raised but is going to ride rougher.
Set the preload to your liking. You will probably have to put them on the car and see how it rides and then adjust accordingly. The front two should match each other and the rear two should match each other on preload. You can set them so they are all the same also.
With Koni shocks they must be springs.
If adjustable could be these
http://thmotorsports.com/i-239552.as...FVFp7AodSBoAzQ
CarStuff
Dec 6, 2020 12:52 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
