Noob looking for some suspension info
Old Apr 26, 2010
Bonnanz's Avatar
Bonnanz is an unknown quantity at this point
I just burst onto the honda civic seen. I have a 1997 civic DX coupe with a manual transmission. I prefer to keep most things stock (just to be differant). However i would to adjust the suspension. I want to lower it and i understand i should use coilovers. How should i go about this whole process? What else has to be done for a successful installation? what kinds should i buy? Id appreciate any info.
Thanks
Bonnanz
Old May 2, 2010
LVSL3PR's Avatar
LVSL3PR is an unknown quantity at this point
Re: Noob looking for some suspension info
Necessary pieces:
Camber kit if you dont wanna buy tires every year, at least the front.
washer trick in the rear.
springs, and stuts, or coilovers.
Classic setup would be Ground Control adjustable coils, and koni yellows, but it really depends on your plans for the car and how much you wanna spend.
Old Jun 5, 2010
mahout's Avatar
mahout is an unknown quantity at this point
Thanks
Bonnanz
Why coil overs? You can purchase loweru=ing springs in 1", 1.5", 2" and even 2.5" drops. We recommend you stick with drops no more than 1.5"; anything more will have suspension difficyulties in alignment, rubbing, poor ride, etc.
You can of course use coil overs but most are pretty high rate springs that offer stiff rides.
wootah88
Jul 21, 2015 10:22 AM
