Broken suspension bolt
Old Jun 29, 2011
newyota's Avatar
newyota is an unknown quantity at this point
I read as many posts on changing struts as I could and low and behold I went to loosen the lower strut mounting bolt and the head broke off!!!!I heard of the pinch bolts braking but not this one.I really did not even apply that much pressure to it!Now something else I saw was the nut is welded to the strut assy. from factory.So the bolt is stuck in the nut.I tried to heat it with a small propane torch and put vise grips on the end that is sticking out of the nut with no luck!!Afraid to heat it up too much cause the rubber bushing started to smoke.Now what?The strut should not go anywhere.I was just getting prepared and do not have the new struts yet.Hopeing to just loosen things up.I am afraid if I use a big torch I will ruin the bushing.What happens if the bolt on the control arm to the knuckle breaks?I don't want to have to replace the bushings too.Please help. thanks
Old Jun 29, 2011
MindBomber's Avatar
Live for the Twisties
Re: Broken suspension bolt
Cut the bolt welded to the strut off and you'll be able to punch the bolt through, replace that with a new bolt and nut until you get the new struts.
Old Jun 29, 2011
did you apply PB blaster? they do miracles (for the remaining ones, i mean)
Old Jun 29, 2011
newyota's Avatar
Thanks-Do new struts come with a welded on nut?What if the bolt is seized to the metal sleeve in the bushing?What about the lower control arm bolt.Scared to even try that one.Should I get a torch and try to got that route before trying to loosen.If I break that one off I will have a bigger headeche for sure.Just read a thread on here where that happened to someone else and could be an expensive repair.
Old Jun 29, 2011
Originally Posted by newyota
Thanks-Do new struts come with a welded on nut?.
they are not welded to the strut, but to the arms
What if the bolt is seized to the metal sleeve in the bushing?.
PB last
PB Blast
Old Jun 29, 2011
newyota's Avatar
thanks,but the nut is welded on the part of the strut that connects to the control arm on my OEM struts
Old Jun 29, 2011
huuuunh... can't remember any welded nut to the struts... Which year car? they have differences between a 01-02 to 03 and to 04-05?
Edit: for some reason, i thought yours was a 7th gen... 6th gen is different... fugget my comments... Duh!
Old Jun 29, 2011
sorry, that was a different car... memory failing before 40 year old...
loggin off now for brain refreshing...
PB Blast comments still stands :P
Old Jun 30, 2011
newyota's Avatar
Just got some input from an experienced mechanic.Said this is a common problem and he usually prices the job out with a new control arm and or usually has to cut the strut off and replace the bushing.I'm just concerned now if I try and loosen the other bolt on the end of the control arm and break that off, I'm screwed since that is in the knuckle/break drum assy.
Old Oct 14, 2011
daniel_honda's Avatar
daniel_honda is an unknown quantity at this point
weld another bolt to the part thats sticking out if possible and it may come out just my 2 cent
juror
Suspension DIY
Jul 30, 2019 03:28 AM
WaryDriver
Aug 16, 2015 11:22 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
muttleytm
Jul 14, 2015 05:31 PM
ballmich
Jul 9, 2015 11:59 AM
