Scraping and grinding noise in the back. Please help!
Old Jul 4, 2010
98hondacivic's Avatar
98hondacivic is an unknown quantity at this point
I have 1998 honda civic dx with 80,000 miles on it. I only hear these noises when I make a sharp or hard turn or when I am going over a bump or a dip in the road at a fast speed. I think the noise is due to my tire rubbing against the body of my car because I have noticed some unusual wearing of the side of my rear tires. But I don't know why it's happening!
So here's the scoop. I bought this used car about a year ago. The guy who sold it to me has lowered the car and has also installed 17" custom alloy wheels on the car. I just replaced the rear tires about half a month ago because I was driving from Pittsburgh to LA. Before I installed the new tires, there was never any such noises. It's only after I installed them that I began to notice the noises. I made sure the new tires are the same sizes as the old ones which were pretty worn out.
So I guess my question is what could be the cause of these new noises? It's really annoying and I know the rubbing is definitely bad for my car. But how can I fix it? When I was getting my oil changed the other day, the mechanic there told me that my rear suspension system is pretty old so that might be causing it. Given the mileage on my car, would that be a likely diagnosis? Do I need to replace the whole rear suspension system? He also told me that my rear trailing arm bushings are kind of worn out, which I could see myself. The rubber parts have cracked and are coming off. Could that be the problem them? Would installing new bushings alone fix the problem? I'm driving my car everyday now in LA and have to make it back to Pittsburgh at the end of August. I just want to make sure there is nothing serious because I want to postponing fixing the problem 'til I get back since labor fee here in LA is so expensive.
Please, any help or advice will be greatly appreciated!
Old Jul 4, 2010
Re: Scraping and grinding noise in the back. Please help!
worn shocks can cause alot more bounce, which would increase the chances of rubbing the tires, esp lowered on 17s.
JetsterDajet
Aug 15, 2015 08:07 AM
15EXCoupe
Jul 30, 2015 12:59 PM
breanna_17
Jul 21, 2015 04:01 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
1khilari
Jul 9, 2015 08:12 PM
