What is the camber kit to civic 2000 lx?
Hi
I have a Civic Lx of the year 2000; I put three year ago the wheels 18" with tires 215 X 35, now the tires are smooth on the inside; the mechanic say that I need to buy front/rear camber kit.
I found many manufacturers of camber kits to Honda, eibach, skunk2, megan,ingalls etc, I choose the iebach camber kit, but my question is, what models work to my car?
This list is the tirerack.com
1) Front Fitment
Note: Camber Degrees of Adjustment +1.0-3.0
Front Fitment Only Designed to resuse OE ball joint
Price: $208.00 (pair) Special
Estimated Availability: Fewer than 3
Manufacturer Part #: 5.62010K
2) Front Fitment
Note: Camber +1.50 to +3.00.
Front fitment
Price: $149.00 (pair)
Estimated Availability: Fewer than 4
Manufacturer Part #: 5.67330K
3) Front Fitment
Note: Camber +3.50 to -2.50
Front fitment.
Price: $285.00 (pair) Special
Estimated Availability: Special Order
Manufacturer Part #: 5.72150K
4) Front Fitment
Note: Camber -1.50 to +1.50.
Front fitment.
Price: $151.00 (pair) Special
Estimated Availability: In Stock
Manufacturer Part #: 5.67135K
5) Front and Rear Fitment
Note: Performance Control Arm
Price: $161.00 (pair)
Estimated Availability: Fewer than 2
Manufacturer Part #: 5.69100K
6) Rear Fitment
Note: Rear Toe Adjuster.
Price: $144.00 (pair)
Manufacturer Part #: 5.69450K
7) Rear Fitment
Note: Camber Adjust: -2° to +5°
Rear fitment.
Price: $103.00 (pair) Special
Manufacturer Part #: 5.67030K
Thanks for your comments
1) Front Fitment
2) Front Fitment
Front fitment
3) Front Fitment
Front fitment.
4) Front Fitment
Front fitment.
6) Rear Fitment
7) Rear Fitment
Rear fitment.
Re: What is the camber kit to civic 2000 lx?
Because of the suspension design, there are a few types of camber kits for your civic.
Here is an article on one set up
http://www.spcperformance.com/PROD_D...02_CIVIC99.PDF
For the front, you can get an adjustable control arm with a ball joint. Or you can just get an adjustable ball joint.
For the rear, it is best to can get a regular camber kit that adjusts and an aftermarket control arm.
http://www.spcperformance.com/PROD_D...ROD_SEARCH.cfm
