ebay "coilovers"
Old May 8, 2014
Jfudge01's Avatar
Jfudge01 is an unknown quantity at this point
ebay "coilovers"
Ok so im new to my 97 ex coupe and the left side of the car rides 1.5 inches lower than the right. Im fairly sure I need new springs, or struts or both.
Now I know you usually get what you pay for, but I am wondering if anybody here has actually used the type pictured here
http://www.ebay.com/itm/RED-JDM-Adjustable-Suspension-FRONT-REAR-Coilover-Lowering-Spring-Sleeve-Kit-/111068711521?pt=Motors_Car_Truck_Parts_Accessories&hash=item19dc360a61&vxp=mtr
Also, to further my lack of knowledge about my car, I am right to assume I have struts all the way around correct? The reason I ask is because I thought coilovers only worked with shocks.
Also, im not a racer just a guy that wants my car to ride at an equal height all around. I assume there wilk be a fluery of "dont buy ebay..." which is okay but I would like specific examples as to why if you could enlighten me. Thanks!
Old May 8, 2014
Jfudge01's Avatar
Re: ebay "coilovers"
I would also like to know, if I am going to have my car sit lower (I find 1-2 inches lower to be pretty cooo looking) do I need to replace the control arms and get camber kits.
Or will it still be ok?
Old May 9, 2014
Poopies's Avatar
Super Moderator
Yes, with suspension parts cost usually correlates to quality in most cases. I would trust that cheapo set about HALF as far as I could throw it, and I'm no baseball player. My guess is that your car either has its original springs cut (a horrible way to lower a car) or a crappy aftermarket set. OEM springs are pretty tough and last a LONG time. There are plenty of good options out there. Just search the forums a bit!
It depends on who you talk to, but probably not for the 1 inch drop, probably so for the 2 inch.
Struts/shocks reduce the "bounciness" of your ride so that it's more comfortable. Here's a car with no rear shocks slamming the brakes. I LOVE this vid!
The springs are the things actually pushing down on the wheels. If you want to lower the car, you get a set of lowering springs. If you're using shocks/struts made for stock ride height (i.e. OEM), they might not be able to handle the increased compression since they will have less room with which to work. Manufacturers usually list drop distances so it's relatively easy to find a spring/strut combo.
Coilovers (especially adjustable ones) are usually the preferred option because they combine the best of both worlds. They can also get REALLY expensive.
Do yourself a favor: save up for something nice. You and your passengers won't regret it.
Old May 9, 2014
GolNat's Avatar
Prelude Owner
Your springs will break and the rates won't match between them.
Save up and get some Ground Controls. Or go to a junk yard and get OE springs.
Old May 9, 2014
BlueEM2's Avatar
Whachya lookin at?
Look at some coilover failures and you will be scared away from these. Failure could result in death. Save up and get good ones.
Old May 9, 2014
no mention of spring rates makes me worry, first of all...
2nd, about you car heights, could be anything making that happen. See this guy here, for example.
https://www.civicforums.com/forums/2...ken-strut.html
lift car and inspect to see what is causing it first, could not even be about springs or shocks.
Ah, to answer the "strut", your car have front double wish bones, so technically it's called shocks.
Old May 16, 2014
Jfudge01's Avatar
Thank you for all your help guys. I did some research on bad coilovers and am weary of these.
The question I have now, is just so I know what im getting into..if I am going to lower my car 2 inches, then what all do I need to replace?
Upper control arms, lower control arms, or both? Anything else?
Old May 16, 2014
the ones sold as adjustable would be good to adjust camber (believe they were the uppers on the front)
jdh022764
18
Nov 3, 2015 06:44 AM
zeshan7616
Sep 15, 2015 12:24 PM
rayman009
Sep 12, 2015 08:30 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
