PDA
View Full Version : Suspension
  1. Loose strut rod nut
  2. Suspension suggestions
  3. Question about Suspension for 2015 Civic
  4. Help
  5. Possible wheel bearing problem please help
  6. civic 2013 torque sensor coil resistance
  7. Replacing rear struts and bearings and sway bar connectors
  8. 2014 Civic ex
  9. Grinding and Clunking
  10. 2013 steering rack
  11. Swaying issues
  12. Frt Hub bearings replacment ?
  13. Unable to find hub bolts
  14. Bearing replacement
  15. Power steering leaking when front end is jacked up
  16. Civic 8th gen 2010 Rear suspension bushing replace
  17. Tell what kind this is makes no sens
  18. 2012 Civic vibration above 50 mph
  19. 2014 Hatch feels harsh - transfers every crest to chassis - shocks will help?
  20. What struts fit 2015 civic LX
  21. 2010 LX-S 130 k miles. Mystery shimmy when slowing [solved]
  22. Clunk on bump [solved]
  23. Driveability issue
  24. ABS VSA light and vibrations over 65mph 08 2.2 cdti
  25. Frt Hub bearings replacment ?
  26. 2012 civic lx EPS light came on
  27. Front end rattle on bumps
  28. Steering rack mounting bolts need to be tightened
  29. 2012 civic Rear toe adjustment [solved]
  30. 2012 Civic, front end "howling/whining noise.
  31. Help with replacement parts ordering
  32. front ball joint replacement info plz
  33. Axle Nut Torque
  34. 2006 Civic EX Lower High Pressure Line - Power Steering
  35. Steering Knuckle Assembly
  36. Vibration at 55-60mph under load
  37. Steering Issue for 2012 civic
  38. 2008 Hybrid - TPMS light is on but tire pressure is fine
  39. Rack and Pinion - Steering Column Bolt
  40. Front end issue
  41. Determining Which CV Joint is the Offender
  42. EPS Motor removal. 06 civic si
  43. Replace Struts - need alignment? [solved]
  44. Needing stronger suspension - stock height preferred
  45. Clunking sound when turning right ‘09 Si
  46. EPS issues 2012 4 cyl
  47. Replace Struts and Shocks?
  48. Tourer Adaptive Rear dampers, where to buy?
  49. 2009 Sedan Si vs Coupe Si strut assembly
  50. Rack and Pinion Replacement
  51. 2010 Civic Axle boot question?
  52. Power Steering Feed Hose replacement [solved]
  53. Drilled through rear shock bracket
  54. Worth keeping or not?
  55. Steering Column Came loose
  56. Odd Noise from Suspension which disappears when driving
  57. Car shakes when you brake but the steering wheel dose not
  58. Unusual Front Wheel Bearing Sound
  59. 2012 Civic EX: Power Steering EPS: 39980-TR3-A11 vs 39980-TR0-A11 [solved]
  60. mild screeching noise when turning left or when accelerating
  61. 2006 Honda Civic steering wheel issue....
  62. 2013 civic feels “loose”
  63. Strut/ shock choices?
  64. Rear toe
  65. 2010 DX-G hydraulic rack conversion
  66. Power steering leak [solved]
  67. shaking when cornering to the left and going up a hill @ around 75km/h
  68. 2010 Civic - Loud noise when pressing gas at high speed, stops instantly when braking
  69. 2015 Civic Rear Knocking Sound
  70. TPMS Light Staying On
  71. Wheel Bearings 2008 DX
  72. Tire size
  73. Steering too much hard to turn. Can't even move the vehicle properly
  74. What does this (circled image) do?
  75. Loud Creaking noise when turning Wheel
  76. 2013 Honda Civic EX Coupe - Screeching Noise from Front-Left Wheel Well
  77. Tire DSide wont move whith the wheel
  78. Humming/grinding in front end. Need help diagnosing!
  79. Steering Wheel is REALLY stuck and supposed to drive to prom tonight :(
  80. Lug nut - 2007 Honda Civic
  81. Power steering Hose replacement
  82. Loose squeaky rattling sound
  83. 2012 Civic EX Strut-adjacent parts?
  84. 2009 ex coupe at
  85. 2009 ex coupe at
  86. Which struts to get?
  87. Rough ride
  88. Steering Rack Popping
  89. Alignment 2010 lx-s 90k miles
  90. 2011 Honda civic ride not smooth
  91. Power steering tight after starter replacement.
  92. Worn front control arm bushings
  93. Scratching Sound When Turning Wheels
  94. Loud bang with wheel hop
  95. Front LCA 06' Civic
  96. Stiff steering
  97. 2010 LXS Left clunk suspension
  98. Regular quick struts and shocks vs coilovers
  99. Compliance Bushing 2010
  100. speed sensor not working
  101. Honda Civic 2015 EX Shock Replacement
  102. Front strut failure?
  103. Hum noise when I'm driving at 30-50 mph in back rear
  104. hit a curve
  105. 2006 Civic, LX 1.8L Struts
  106. 2012 civic si thumping/spinning noise coming from tires/brakes?
  107. riped boot
  108. Wheel Bearing & Hub
  109. Alignment done: worthy of new tires?
  110. Grease when changing tire?
  111. Front right suspension rattle after heating up
  112. Wheel Bearing Problem - Honda Civic 2007
  113. Hard to steer
  114. Shock absorbers
  115. 2013 Civic Front Drivers Wheel Assembly Loose
  116. Can anyone identify buzz saw noise? In reverse, right rear wheel.
  117. 07 civic driver side front wheel toe in when straight???
  118. Front wheel positive camber
  119. Power steering issues
  120. Steering looser after new shocks
  121. Cheap tires
  122. Urgent: How to remove the power steering pump
  123. Alignment
  124. 2009 Civic 1.8 (base model) HIgh Speed WHEEL SHAKE
  125. Loud humm noise at certain speeds from front end
  126. Aligned but not aligned
  127. Broken control arm
  128. 2012 civic ex Front Wheel bearing
  129. check power steering message- 2015 civic si
  130. 2008 Civic LX Rear Passenger Issue
  131. Front wheel bearing
  132. Rear Suspension Rattle
  133. 8th gen Civic clunk
  134. 2015 honda civic rear grinding noise
  135. Car pulling to left and right, also more bumpy than usual.
  136. 2008 Honda Civic Alignment
  137. 8th gen 2008 Honda Civic Sedan - can shops not fix bad front camber?
  138. Rattle noise from Strut/Rear Deck (2015)
  139. Rear Upper Control Arm
  140. Front wheel tire tread issue's
  141. 2007 Honda Civic EX - Four Wheel Alignment Failed
  142. Steering feels loose even tho mechanic says it's fine
  143. Rotation knocking sound near wheels
  144. TPMS Calibration Not Available on IMID screen
  145. 07 civic rear wheel noise
  146. Civic 2012 vs 2013 Alignment Specs
  147. Road sound heard in cabin when driving..
  148. 2012 Honda civic exl unstable on highway speeds
  149. 06-07 Rapid Tire wear/ class action lawsuit
  150. Class Action Lawsuit for Upper Control Arms 2006/2007 Civic/Civic Hybrid
  151. Shaking steering wheel
  152. Honda lower control arm
  153. 2007 Honda Civic Coupe handles badly
  154. Need a wheel bearing DIY for 8th gen civic
  155. Unusual steering noise
  156. 07 civic rear upper control arm
  157. tire gauge warning light
  158. 2006 Civic Power Steering Leak
  159. ran my new 2010 civic off road - need help
  160. Steering shakes when you turn the wheel
  161. front end problems steering wheel jerking while driving
  162. OEM tires how many miles have you all got?
  163. Do all Civics eat tires?
