shaking when cornering to the left and going up a hill @ around 75km/h
Old Dec 28, 2021
Nidal's Avatar
Nidal is an unknown quantity at this point
Angry shaking when cornering to the left and going up a hill @ around 75km/h
Hi,
I have a problem with my civic, it shakes badly when driving up a hill at around 75KM/H and when cornering left.
I was told it was a left CV joint problem i changed a complete used one (Inner and outer), also changed the front bearings (left and right) and did alignment and wheel balancing with no luck.
Any body can help with the cause of this
Thanks.
Old Dec 28, 2021
FRSam's Avatar
Click Here
Re: shaking when cornering to the left and going up a hill @ around 75km/h
I would verify the used part you put in is good.
I had a car that had similar symptoms and it turned out to be the steering rack.
RajanKumarSingh
Mar 31, 2018 08:34 PM
max785
Aug 24, 2011 08:04 PM
teampointless
Texas
Sep 13, 2004 09:49 AM
civic4dizoor
Nov 7, 2003 07:58 AM
