Stiff steering
Old May 5, 2020
Zeyad's Avatar
Zeyad is an unknown quantity at this point
Stiff steering
  1. Hi guys.. My 2007 civic PS stop working.. Earlier i was found leaking from hose in rack.. Get it fixed.. right After fix PS stop and work for 7 days maybe... Now it stop permanently.. What can be the problem?? Did i need to bleed the air?? Also i found a cut in a hose that come from reservoir going to radiator.. Please help.. Thanks you all
Old May 14, 2020
Trlane01's Avatar
New Member
Trlane01 is an unknown quantity at this point
Re: Stiff steering
If there is a cut in the line for the PS fluid, replace line. Check the PS pump itself. If your PS has stopped completely it's likely the pump has failed.
Old May 14, 2020
Zeyad's Avatar
Re: Stiff steering
Yes i replaced the line.. Still no power at all.. How to check the pump?? Thank you
MetalAttack 666
Suspension
Dec 2, 2021 06:35 AM
teezyyoxo
May 4, 2017 10:36 PM
Sailorman3
Nov 10, 2013 11:27 AM
Tag2
Sep 6, 2011 02:49 PM
cobrapimp
Bolt-on Engine Performance
Mar 5, 2003 02:08 AM
