Power Steering Hose Isseus...
Old Feb 5, 2011
MetalAttack 666's Avatar
MetalAttack 666 is an unknown quantity at this point
Question Power Steering Hose Isseus...
I have a 2003 sedan and have had to replace the power steering return hose to the reservoir twice already within a year. The problem is that for some reason the reservoir will pop out of its holder and the hose attached will be sliced by the belt. Has anybody else had this problem? Any ideas for a solution?
Old Feb 5, 2011
CraigW's Avatar
Re: Power Steering Hose Isseus...
You might be able to slightly crimp the holding bracket [ a little bit (don't go crazy) and it would hold tighter.
Old Feb 5, 2011
i think there is another problem if the reservoir is moving. mine is very loose in the holder and its never popped out. does the hose have the factory clamp around it by the engine?
Old Feb 5, 2011
MindBomber's Avatar
Live for the Twisties
I've never heard of that happening before, so there must be some sort of other problem causing it. As a patch repair I'd drill a hole in the bracket and bolt the pump in place.
Old Feb 5, 2011
That is actually a pretty good idea. I just zip tied the hose to hold it place for now. Its really a strange problem though.
It still does have factory clamps but I don't see how that really would affect anything except it leaking.
Old Feb 5, 2011
MindBomber's Avatar
Zip ties are endlessly useful.
If I though it were something major then I wouldn't suggest adding a bolt, but I think it's probably just the bracket being bent slightly.
Old Dec 2, 2021
ZealousLove's Avatar
ZealousLove is an unknown quantity at this point
Following up on a unanswered question from the first post, what is part #3 called. That part broke on mine a idk what is called for the life of me.
Old Dec 2, 2021
BrotatoChip's Avatar
Super Moderator
10 year old thread....and you didn't give us enough info to answer your question. Part #3 in what diagram?
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
hans.pcguy
Jul 12, 2015 12:19 PM
vvr210
May 31, 2015 08:02 PM
EdGasket
May 25, 2015 01:06 PM
