2014 Civic ex
Old Aug 7, 2025
Timbogates's Avatar
Timbogates is an unknown quantity at this point
2014 Civic ex
The car has a bump and knocking type noise that occurs at speeds less than 20 miles per hour that you can hear. It has a 150,000 MI and is in good shape. Could this be ball joints or what other possibilities because when I turn it sharply back and forth you do not hear any grinding or popping. It does have the original shocks and struts. What would be the more likely items?
Old Aug 8, 2025
GolNat's Avatar
Prelude Owner
Re: 2014 Civic ex
If it knocks over bumps could be the strut mounts going bad.
Old Aug 12, 2025
Timbogates's Avatar
Re: 2014 Civic ex
If it is strut mounts and this is original equipment struts would this be a easier replacement than replacing the entire strut itself?
Old Aug 14, 2025
David13's Avatar
David13 is an unknown quantity at this point
Re: 2014 Civic ex
This is basically what I seem to have on my 2015.
I have come to believe it is the front bushings on the lower front control arm, aka the 'compliance' bushing.
I need to replace them and see if it solves the issue.
dc
Old Aug 17, 2025
Re: 2014 Civic ex
lift car and start prodding around with a prybar
Trainingdragon
19
Jan 8, 2012 11:45 AM
Loretta7$
May 9, 2010 11:52 PM
dcjose20
May 11, 2008 09:59 PM
shamubro
Feb 1, 2006 10:54 AM
Civic_RedLine
Sep 11, 2005 12:00 PM
