Front end issue
Old May 18, 2023
NeuroDivergent's Avatar
NeuroDivergent is an unknown quantity at this point
Question Front end issue
Good day all! New to the forum here, on my second Civic. First was a 97 coupe, now with a '07 sedan. So far, great cars to work on! Anyway, I've got a lovely pulsing sound coming from the driver's side front wheel area. Not clickity-clack like CV joint and not exactly metal scraping like rotor. It does increase with speed and when cornering it's quite noticeably louder. Sorry but, it's basically a low pitched, "wuh wuh wuh." Here's the thing: I can rule out bad tires and brakes because I jacked up the car, pulled the wheel and caliper, set the parking brake and put her into drive and the noise was still there. Also, I noticed that just leaving it in drive and not stepping on the gas at all, the axle was turning but it kept, "getting stuck" like it was hitting resistance. I don't THINK it's the CV axle and I'm leaning heavily to wheel bearing but not 100% sure. With the bearing requiring the press and hub remover I don't want to commit to investing in the extra tools if it's likely something else.
Any suggestions on what the likely culprit is here?
Thanks!
Old May 18, 2023
Colin42's Avatar
Re: Front end issue
Wheel bearing, you could take the knuckle to a shop and get them to press in the new bearing
Old May 18, 2023
Re: Front end issue
And press the old one out? That could work. Rockauto has them for like $15-$20 and I'd rather throw cash at a shop than buy all the stuff for one repair.
And one more vote for wheel bearing. Thanks!
Old May 18, 2023
Colin42's Avatar
Re: Front end issue
Yep they'll press out the old and press in the new. Shouldn't cost much at all
Old May 18, 2023
Re: Front end issue
or get a harbor freight press, should get paid in a couple things you press out and in (ball joints, control arm bushings, etc)
bachands
Transmission
Oct 2, 2020 05:47 AM
silentz
Jul 6, 2017 01:51 AM
BiggSean
Aug 10, 2011 11:29 PM
Miz017
Jul 8, 2010 05:27 PM
20_CiViC_02
Wheels and Tires
Aug 19, 2009 02:36 PM
