Axle Nut Torque
Old Jun 12, 2023
DaddyDingDong's Avatar
DaddyDingDong is an unknown quantity at this point
Axle Nut Torque
I changed out my hub and bearings on both front knuckles and when putting the cv axle back into the hub I'm having a hell of a time. I read that you just push the spline in enough to where it lines up w/ the hub and then torque it down until it bottoms out and reaches the OEM torque spec. Only issue is I'm over 150 ft lbs of torque and I'm not even 1/3 of the way close to bottoming out. I've read about other cars taking 300-400 ft lbs of torque but I am worried I'd damage the CV axle and hub if I force it. suggestions?
Old Jun 12, 2023
Re: Axle Nut Torque
what year and trim? I've seen different specs for 7th vs 8th vs 9th gen, and different specs for Si vs non-si.
Old Jun 13, 2023
BrotatoChip's Avatar
Super Moderator
Re: Axle Nut Torque
The axle should easily slide into the hub and completely bottom out without the help of the axle nut. If you're using the nut to pull the axle into the hub, something is definitely wrong.
Does the number of splines on the axle match the number of splines in the hub?
Old Jun 13, 2023
Colin42's Avatar
Re: Axle Nut Torque
Agreed something isn't right, should slide in nice
Old Jun 13, 2023
Re: Axle Nut Torque
are your antiroll bars still connected? That makes harder to align the shaft
Old Jun 13, 2023
Re: Axle Nut Torque
2015 Civic EX-L
Old Jun 13, 2023
Re: Axle Nut Torque
That was my thought as well. Wondering if AutoZone gave me the wrong hub.
Old Jun 13, 2023
Re: Axle Nut Torque
Yes, the entire suspension and steering are assembled. I've never had this kind of problem in the past.
Old Jun 13, 2023
Super Moderator
Re: Axle Nut Torque
Remove the nut and pound the axle back out to see the damage. For what it's worth, the torque spec is ~134 lb ft.
Mr Radio
Transmission
Mar 25, 2019 02:15 PM
butterblum
26
Nov 15, 2016 08:58 AM
jimmyjack
Aug 8, 2015 10:54 PM
fluxgame
May 15, 2008 01:39 PM
duyaknow
May 18, 2003 01:02 PM
