cv axle removal pass side
Old Mar 16, 2019
Mr Radio's Avatar
Mr Radio is an unknown quantity at this point
i am trying to remove the passenger side axle on my 2009 Civic. I looked at a couple of videos but they all show a
long axle going directly into the transmission. My car has a short axle, a carrier bearing and then a torque tube going
into the transmission. Any hints on removal? The drivers side came out normally.
thanks
bill
Old Mar 17, 2019
Re: cv axle removal pass side
The inboard cv joint comes off of the straight shaft.
It's held together with a snap ring, same style as the opposite axle has holding it in the transmission.
I usually use a large brass drift and hammer to drive them apart
Old Mar 25, 2019
Mr Radio's Avatar
Thanks, I will give that a try.
I got a large crowbar in there and it would not move. I will try a drift.
Funny all the videos show a long axle. (PS I said a torque tube, which it is not, as it rotates with the axle)
Old Mar 25, 2019
Mr Radio's Avatar
well did not have a drift large enough as the space is larger, but I was able to use it to tap the axle out.
Turns out that the pass side axle is female on the inboard side.
Thanks so much for your input.
Bill. B.
samuelito210
23
Sep 10, 2014 09:48 AM
yeabmx
20
Oct 16, 2009 11:45 PM
BenDover
Sep 16, 2009 09:05 PM
BenDover
Sep 16, 2009 01:45 PM
integ108
Aug 24, 2003 05:15 AM
