TPMS Calibration Not Available on IMID screen
Old Apr 26, 2015
hewey23's Avatar
hewey23 is an unknown quantity at this point
Hi Folks;
I recently put my Spring/Summer tires on my 2014 Civic EX. When I try to Calibrate the TPMS, it is not available in the IMID Menu.
Ignition to II
Press MENU and go to Vehicle Menu
Customized Settings, then press the SOURCE button.
TPMS Calibration not there to Select.
Any Ideas?
Thanks
Old Apr 26, 2015
Re: TPMS Calibration Not Available on IMID screen
Is the TPMS selection grayed out, or is it missing altogether?
If it's grayed out then conditions aren't right.
Try it with the engine running.
Shifter in park. (if manual trans, shifter in neutral and handbrake set)
From the owners manual:
1. Turn the ignition switch to ON
2. Press the MENU button to go to the
Vehicle Menu screen.
3. Select Customize Settings with the (+/(-
button, then press the SOURCE button.
4. Select TPMS Calibration with the (+/(-
u The display switches to the
customization setup screen, where you
can select Cancel or Initialize.
5. Select Yes with the (+/(- button, then
u When the calibration is complete, the
The TPMS has been initialized.
message appears, and the display returns
to the customization menu screen.
• If the Unable to initialize TPMS. message
appears, repeat steps 4-5.
HTH
Old Apr 26, 2015
hewey23's Avatar
Thanks for the quick response.
I've tried it with the car started and off. The tpms calibration is not in the menu to be selected.
Old Apr 26, 2015
Oh wait, you are in Canada?
Does the car even have TPMS at all?
Do you have the butt icon idiot light "(_!_)" in the tach cluster?
If nothing else, go to the dealership, hopefully it's still under warranty.
Old Aug 3, 2020
Andy Davies's Avatar
Andy Davies is an unknown quantity at this point
I have exactly the same issue Civic Tourer 2014. I have previously been able to recalibrate but the option no longer appears. Did you resolve it?
Andy
Originally Posted by hewiey23
Hi Folks;
Ignition to II
Any Ideas?
i have exactly the same issue. The TPMS option is no longer there. I have previously had it available and been able to recalibrate after inflating tyres following warning light. Did you solve it?
Andy
Thanks
Old Aug 4, 2020
Andy
Disconnect the battery, wait 20 min, reconnect battery. See if menu returns to normaal
Old Oct 15, 2020
skramer's Avatar
skramer is an unknown quantity at this point
HTH
my sons 2012 civic DOES NOT have the option for TPMS Calibration (#4 above). Every video that I have watched takes me right to that option. When I scroll up, this option is not even available to choose. Any suggestions?
Old Oct 16, 2020
BrotatoChip's Avatar
Super Moderator
Did you try this?
Old Jan 20, 2021
Emil Mihov's Avatar
Emil Mihov is an unknown quantity at this point
I have the exact same issue with my CRV 2013. When changed tires last year the TPMS calibration option was there but this year it's just gone (not grayed out, gone). On top of that when TPMS light is on, I cannot turn off traction control which makes it harder to get out the snow if the car is stuck somewhere. I tried removing the battery for 30 min which reset everything but the option was still gone. Searched for firmware update options but there aren't any. Scanned the car at my friend's garage and removed all the error codes. That cleared the TPMS light for 1h then it came back on and the TPMS calibration option is still gone from the menu. The car is out of warranty so any ideas would be greatly appreciated.
Old Jan 31, 2021
How long has it been since the last time you had to do the tire reset yourself or anyone else know for certain it was used
and has the car had any work done between then and now.
Normal. See owners manual.
Old Jul 7, 2022
Valve_UA's Avatar
Valve_UA is an unknown quantity at this point
Hi everybody.
Got a Civic from America. canadian version.
Same problem here: there's no sensors or TPMS control unit according to official EPC.
But TPMS light is blinking and i can't find TPMS initialization in the menu...
Old Sep 4, 2022
hectorluis1331's Avatar
hectorluis1331 is an unknown quantity at this point
Originally Posted by hewey23
Hi Folks;
Ignition to II
Any Ideas?
Thanks
did you fix it ? I am having the same problem
moffett
Apr 2, 2014 07:09 PM
DSTANK
Mar 26, 2011 06:26 PM
regor
Nov 3, 2008 11:31 PM
civicmorph
Dec 17, 2003 08:56 PM
bbbindc
Jan 29, 2003 09:26 AM
