Drilled through rear shock bracket
Old Oct 28, 2022
kingk's Avatar
kingk is an unknown quantity at this point
So the previous owner had stripped the rear shock bolts and we were able to get one out with an extraction kit but the other wouldn’t budge so we ended up drilling through the bolt to get it out. That led to us drilling a the threaded part of the bracket. I can’t find the part online though no matter where I look so I was wondering if anyone knew of a place to find it or if it just be easier to find another 07 lx and just grind off and weld on the new part from another car.
Old Oct 28, 2022
FRSam's Avatar
Click Here
Re: Drilled through rear shock bracket
Very likely the latter. Have you tried searching with a part number?
Old Oct 28, 2022
Colin42's Avatar
Cut off the old nut, use a new one, weld it on if you feel like it
Mary Bradley
Brakes
Sep 1, 2020 09:07 AM
robbclark1
Oct 10, 2006 08:12 PM
CrazyCakes
Jul 9, 2004 11:13 AM
7gen03
Jan 26, 2004 07:45 PM
Alex1
Jan 27, 2002 11:08 PM
